Results 1 to 6 of 6
Thread: JDM DOHC F22B question?????
    'Round These Parts
    Default JDM DOHC F22B question?????
    I will be getting one droped into a 94 Accord DX soon.
    Thinking of replacing the timing belt, is it the same as the US Spec F22b2 Application?
    any other helpful info that should be useful?
    Thanks in Advance
    Leisa and S. 4 Life NM?
    'Round These Parts
    anyone?
    guess since it's not a civic motor...
    Apr 2003
    hm..isn't that the same as the US H23 version (the lude SI). They're very identical to the point that you can use almost everyparts of each others. So my guess is that you can use the H23's timming belts?
    Banned flysi00's Avatar
    ^^^^^ i think the same
    'Round These Parts
    thanks for the input guys...i'll be sure to get it solidified.
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    Main thing to watch out for Kev on the DOHC's is that the number of teeth (splines on the pulleys) match up correctly. A good idea is, if I am not mistaken since I am not sure about the DOHC F22, to replace normal timing belt parts (ie water pump, tensioner, etc) with those of the H23. That way every thing should be the same and match up but since I am not real familiar with this motor you might want to check with Batlground or Vteckidd to be sure.
    www.ATLphoto.net Myspace
