Results 1 to 13 of 13
Thread: 98' Civic EX Problem
    Oct 2008
    Bankhead
    Default 98' Civic EX Problem
    I have a problem with this car because when I shift into 2nd gear it sometimes goes into gear and when I drive slow on 2nd gear it pops out.
    When I shift into 3rd gear it grind. You know when you shift normal into gear, When I do that into 3rd gear it grinds but when I wait about a 2 or 3 secs and then shift into 3rd it doesnt grind. My civic does have an acura transmission and it has 99,xxx miles on it. Also the motor is tweaked, the car was given to me from my cousin. Thanks To Anyone with advice
    Scottish Scotsman's Avatar
    on the road to recovery
    moved
    wanna sell the car?
    syncros
    aye bro .:Stirfry:.'s Avatar
    you need a new tranny
    ATL DAsquad Member #9
    need rebuild and syncros will not fix it I bet money it will need new gear, and bearings also...Your best be is to get a used one. I seen them on here go for 100-175 bucks
    Southside Ridin HATCH
    get a new trans..
    Oct 2008
    Bankhead
    I guess ill get a new transmission then ill have to save up, and im not selling it, im going to have it as my project car. thanks guys
    need a si shell tpike09's Avatar
    Aug 2009
    milledgeville ga
    sounds like you need a tranny but what are you talking about with the acura tranny on a civic ex
    VTEC addict:jerkit:
    JDM TYTE AnthonyF's Avatar
    Cumming
    Quote Originally Posted by tpike09 View Post
    Integra and Civic trannys are interchangeable.
    -Ant.
    The Carbon Fibered R6
    Aug 2009
    milledgeville ga
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    civics come with d series integras come with b series how does a b series tranny bolt up to a d series
    VTEC addict:jerkit:
    AWD
    gainesville
    It dont!
    You guys know there are civics that came with B series engine's right?
    And the new civic has a VERY similar engine to the RSX type-s.
    anyway. yeah your tranny needs work and the synchros and springs on em should be replaced. it can be cheaper to get a good used tranny that wasnt beaten on.
    That 2-3 second wait...during that time the speed of the hub, synchro and shaft are all 'synchronizing'. The synchro is like a little brake pad to match the RPM of the shaft and synchro hub. Good synchros will be able to do this no problem. If the tranny was shifted on very very fast and harshly, the teeth will get gnarled on the hub and not allow it to engage smoothly or even at all if it gets real bad.
