Results 1 to 40 of 52
Thread: i need help with a b20vtec
    Certified Gearhead b20vtecrr's Avatar
    Jun 2009
    423 chatt
    Default i need help with a b20vtec
    i got a 4dr integra and i just put a b20vtec in it brand new its got 1100 miles on it. i drove it to ia it broke down i found oil in the distributor i bought a new one and still it will not crank. i dont know what the problem is can anyone help
    West palm beach
    do you have
    1-fuel
    2-spark
    3-air
    4-compression
    Whats it do when you turn the key ? Lots more info needed...
    Your mom's bed
    x2
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    Did you put the plug wires on the dizzy in the correct order? I have seen this before, people make a mistake and put them in the wrong firing order. Thats why I ask lol...
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    423 KING
    Chattanooga, TN
    we left to go out of town and made it to nashville about a 2 hour drive and it did fine then left to go to ia the next morning and it made it about 15 minutes down the road
    in the land of ozz
    Does it have aftermaket cam gears?
    HELLYEAH!
    423 KING
    Chattanooga, TN
    honestly im not sure, i dont think so
    in the land of ozz
    Hmm, pull a plug wire and see if it has a spark when trying to start it.
    HELLYEAH!
    423 KING
    Chattanooga, TN
    its my friend that owns the car, he needs to get back on here
    in the land of ozz
    Have you tried pulling the ecu fuse and checking if its blown? Doing that will also reset it...
    HELLYEAH!
    423 KING
    Chattanooga, TN
    i think all he has done is tried a new distributor
    Jun 2009
    423 chatt
    all the plug wires and plugs are new
    in the land of ozz
    . turn the key to the on position, listen for the fuel pump
    . check for spark
    . make sure the plug wires are in the correct firing order
    . check fuses
    . check the rotor button
    HELLYEAH!
    B-Town Crunk Force
    Statesboro, GA
    Aw damn dude still havent got it fixed?
    Too bad the bitch didnt just run outa gas like you originally thought.lol
    Jun 2009
    423 chatt
    got fire compression and all that it just turns over with nothing where is the ecu fuse cuz i checkd all the fuses under dash and engine bay
    423 KING
    Chattanooga, TN
    Quote Originally Posted by jdm>usdm
    that was funny as hell we were all like oh ok its just out of gas
    in the land of ozz
    Its located under the hood, normally its a 20amp fuse.
    HELLYEAH!
    Jun 2009
    423 chatt
    exactly i wish it was out of gas
    Jun 2009
    423 chatt
    well ima go take a look and see if its a fuse i didnt see an ecu fuse tho last time i checked
    Jun 2009
    423 chatt
    i mean what else could it be if not the fuse?????????? im lost it cant be blown bc of the way it died it was bogging down
    B-Town Crunk Force
    Statesboro, GA
    Quote Originally Posted by b20vtecrr
    Yeah bro check all of your fuses first. Be positive that your fuel pump is coming on when you turn the key as far as you can before the starter begins to turn the motor over. Sometimes main relays just decide to go bad and not turn the fuel pump on.
    Jun 2009
    423 chatt
    the fuel pump def comes on i loosend it a fuel spewd out as did the fuel rail
    Jun 2009
    423 chatt
    is there a fuse specifically for ecu cuz i havent ever seen one
    in the land of ozz
    Yeah, its under the hood. there should be a diagram on the fuse box cover.
    HELLYEAH!
    Jun 2009
    423 chatt
    alright im gonna go check it out when i get home thanks alot dude ill let you know tomorrow on here what goes down
    in the land of ozz
    HELLYEAH!
    so it turns over and it dont do jacK???
    1. check compression
    2. check timing
    3. check dizzy ignitor
    4. check all wires that it's hooked on correctly on ears of dizzy & ignitor
    /Oo ___A___ oO\
    |=_/_______\_=|
    in the land of ozz
    Quote Originally Posted by VickNotic
    MAYBE timing jumped
    Thats possible, lets hope not though lol.
    HELLYEAH!
    Jun 2009
    423 chatt
    man i totally didnt see that fuse in there im at work but i didnt see one labeled ecu weeiirrdd my dad seems to think its internal cuz when it turns over it just wobbles ahahahahha like a death wobble but nothin is gone bc of the way it died it didnt blow up
    in the land of ozz
    Well without beeing there its hard to tell what the problem may be.
    HELLYEAH!
    Jun 2009
    423 chatt
    i know man shit sucks a fat one
    in the land of ozz
    Im sure its something simple lol. GL...
    HELLYEAH!
    423 KING
    Chattanooga, TN
    i know man, i will still suck a fat one
    fixed for robby
    Jun 2009
    423 chatt
    dude i hope it is
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    did you replace the distributor with a new one? was it a KNOWN working one? you are obviously missing ONE of the necessary elements, if you had spark, fuel, and compression it would run. you need to find out which one you are missing.
    Who knows?
    Jun 2009
    423 chatt
    man i bought a brand new distributor and cap the rotor button is the only used part from the one that went bad would that matter though????
    Jun 2009
    423 chatt
    no go guys and there is no ecu fuse in the engine bay fuse box :/
    Where Am I
    The ecu fuse is actually a back-up-radio fuse, its usually on a honda under the hood. One of the fuses closes to the firewall
    i thought the fuse was under the dash. it should be two fuses by each other
    Where Am I
    Quote Originally Posted by JDMteg08
    The one I've always used to reset the ecu's on honda's are under the hood, by the battery...............
