Results 41 to 52 of 52
Thread: i need help with a b20vtec
    Certified Gearhead b20vtecrr's Avatar
    Jun 2009
    423 chatt
    yea bro i gotta back up radio fuse dunno why it doesnt just say ecu look up earlier in this post dude sent me a link with a picture of a fuse display panel and it actually says ecu what the hell is that off of?????
    the is a ecu fuse under my dash i take a picture and show you. it also says it on the fuse cover
    Jun 2009
    423 chatt
    alright sounds good
    The H is back... CaTcH22's Avatar
    AccuracyPerformanceAutomotive
    Prolly didnt jump timing if the compression is good. Did you check for codes?? Does the check engine light go off or stay on while you are cranking it?? Sounds like a dizzy problem.
    500whp of spinnin fury!!!
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    Is your ecu obd1?
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    Jun 2009
    423 chatt
    obd2 integra type r ecu ive tried my p75 ls ecu (i know its not vtec) ive tried p72 gsr ecu
    Jun 2009
    423 chatt
    i dont know if it has jumped time or not man its got a brand new dizz except for the rotor button idk if that matters or not
    Jun 2009
    423 chatt
    all i know is the plugs and wires and dizz is new and there is NO FIRE AT ALL!! IIIII DOOOO NNOOOTT GGEETTT ITTTT!!!
    in the land of ozz
    Quote Originally Posted by b20vtecrr
    Here is a thought, set your motor to TDC and then take off your dizzy cap and make sure your rotor button is pointed at the number one plug. If its not pointed at number one, that means your firing order is not right... try that and see if that fixes the problem...
    HELLYEAH!
    pm sent i need cliffs
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    jumped timing? maybe even bent a valve?
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    Theres a ground near the t-stat housing, make sure its good, clean, and tight.
