Results 1 to 19 of 19
Thread: How to remove tranny
    Default How to remove tranny
    any1 have a diy or any tips on how to remove b series tranny? Im switching mine for an ls. Info and pics would be good
    pretty simple
    7 17mm bolts
    2 19mm off the rear T bracket
    2 14m off starter
    2 12mm bolt off the slave cylinder
    disconnect the reverse harness
    disconnect the vss harness
    2 jack stands (use it to hold the longblock)
    1 jack (use it to balance the tranny up & down 8D take off pass mount,
    and then bammm
    /Oo ___A___ oO\
    |=_/_______\_=|
    nothing special its pretty straight forward.
    J.R
    Down South
    Quote Originally Posted by k20ej8
    y switch to an ls what do u have now, and since your switching it might be better to just pull the motor out with the tranny more working room it you
    got the right equipment.
    Quote Originally Posted by NOCLUE
    not really a honda tranny is so unbelievably easy to R&R its not even funny.
    J.R
    Down South
    this is true
    I do these in 20 mins start to taking it out and about the same going back.. I spend more time cleaning the new tranny and painting then doing the work...But hey that is why I get the big bucks
    BTW someone forgot to tell you to disconnect the shift linkage, and take out the axles !
    And the dust shield,and engine bracket from motor to tranny supports
    And what about the ground?
    West palm beach
    why are you switching to a ( long geared/garbage ) LS tranny ?
    boost
    West palm beach
    boost
    hella boost I hope...
    why would i want to use a short geard, ill spin out in almost every gear
    West palm beach
    whats your set up now ?
    itr tranny. going boost
    Southside
    and to also drain out the tranny fluid
    I"m sorry bout that, i did 4get to tell'm to disconnect the shift linkage and knock out that one lockk tooth watever it's called 8D .. you never seem to dissappoint me Tech 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    South Side Georgia
    I suggest upgrading the clutch too while you are at it. G/L
    resize pic
    thanks alot everyone. that shit was a BIIIIIITCH!!!
    my response deserves a rep m8 holla 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    ^ Why you left out key infomation my friend!
