Results 1 to 20 of 20
Thread: help please
    paint booth
    Default help please
    i just got my b20/vtec swap in. it came with a chipped p28 and dont want to run and idle's really rough and wont rev without sputtering. i can plug my ecu that was running my d series and it idles up and down and can be driven but at low rpm's it cuts out. i pluged my friends 97 hx ecu in and it still idles up and down but runs alot better. any usefull help will be repped.
    put the chipped p28 in and post back any cel's..
    paint booth
    Quote Originally Posted by 1civic
    ok but i think the SI cluster i have has the check engine bulb missing.
    I would fix it.. .. But it seems you may have plugs backwards, Its not uncommon for people to do.. I would check the Map and TPS since thats the one most people have backwards.. If your sure the are right then check all plug connections, vaccum lines, leaks, etc.. Get that bulb fixed also..
    pretty much... u will have to go thru it with a fine tooth comb and make sure everything is correct. which me personally i dont think u have all your connections correct.
    Southside
    x2
    paint booth
    i had a guy do it and he has done 4 complete swaps and it took him two days to do it. i dont think theres any misplugged plug's. but tell me what to check and i will.
    Newnan
    if it doesnt come on when you first turn the key, it's broken.
    g'luck!
    learn to english
    ... ŁG2♣'s Avatar
    2o9
    good luck on it, id love to see how this run since im in the process of doing one
    paint booth
    i checked the check engine light code and i counted 58 1 second flashes with about 5 or 6 seconds between flashes with the ecu that ran my d series. so with that many flashes that far apart. was it telling me it was a code 10? if so thats the IAT sensor. i will check it tomorrow with the p28.
    . eg mike's Avatar
    ga
    58 1 second flashes
    there is a delayed flash and a quick flash..
    delayed flash = 10
    quick flash = 1
    If there is more than 1 code there will be an even bigger delay for the next code. You know your done when you get the same code twice...
    paint booth
    Quote Originally Posted by eg mike
    58 1 second flashes
    delayed flash = 10
    quick flash = 1
    on honda-tech the sticky about checking code's said "one second flash= 10's and half second flash= 1's.
    paint booth
    ok but what about the code 10 thing.
    check the IAT make sure its plugged up to the correct connector.
    The IAT and the IACV connectors look a lot alike on the harness (that 2 pin barrel connector)
    Generally when they are switched, it will blow Q31 in the ECU, and then you will obtain a solid CEL, which means the ECU is bad as stated earlier-
    Hopefully its just the chip that Xenocron made- Im still waiting to hear back from him-
    paint booth
    how do i check the ecu? i used my friends ecu in mine and put it back in his and his still runs fine.
    Augusta Ga
    if it runs its still good .... which means they were not crossed . i had the q31 done to one of my chipped p28 ecu's for letting someone other than me touch my car ....
    93 sol Si
    95 sol S
    95 sol Si
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    is it an obd 2 throttle body? if you are running an obd1 ecu youll need an obd 1 tps.we usually have to change to an obd1 to get it right if it is. something about the wires pinned different. also the iacv and intake air temp sensor and that little spool valve that has a plug and lets vacume to the purge canister. and the map and tps will interchange as well...
    paint booth
    well i picked up a 97 b20 throttle body today and i am swaping everything like the map sensor and the tps sensor over to it tomorrow.
