Results 1 to 25 of 25
Thread: wheel hopping
    Around metro-ATLANTA & IA!!
    Default wheel hopping
    i have 205/45/16 with 45psi if i got something with a bigger sidewall like a 50 series, would this help from wheel hopping or should i lower the tire pressure on the tires i got now?
    is 45psi whats written on the tire to be the correct pressure? usually the lower the profile the higher the PSI
    i drive slow im_hung's Avatar
    location, location
    try it with 35 psi, that should be the rec. pressure for that tire.
    50 psi is the max psi what it says on the 205/45/15 nitto neo-gen tires, but i have 45psi in them right now and it tends to wheel hop everytime, now my question is if i lower the psi to 25-30 would that help it from wheel hopping
    im not that educated with wheel hop, but i'd say yes it'd help, but a balance may help also. and think about a stabilizer
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    how about getting traction bars
    yea id definatly jump on those if i had the funding....you know where i can get some that are cheap?
    ECEFC.com
    IS300 NEMO's Avatar
    We Fuckin...
    what kind of suspension do you have?
    I don't pull out... E=MC²'s Avatar
    Where we like our sisters...
    i had the same tires on 16's at 32-35 psi and never had that problem. i say just lower the psi a bit.
    i would start with raising the car a lil. ive worked on a few cars that would do that on launch. wheel hop then break an axle. raised them up a 1/2 -1 in all problems stopped. my hatch used to do it also.
    Southside Ridin HATCH
    lower the psi in the front...
    And how soft is your spring setup in the back?
    my car used to wheel hop when the tires broke loose in 1st. when i installed my new wheels/tires, james and i adjusted the toe and it hasn't wheel hopped once. i have a traction-bar to install, but haven't gotten around to doing it yet, but at this point i think the toe was the problem.
    check the alignment and toe.
    the rear is stiff as shit almost no movement they are drag coilovers from omni power
    Quote Originally Posted by Black4DrEK
    warner robins
    Quote Originally Posted by LongLiveH2b
    same thing i have, they are really stiff
    JJSPEC.COM
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Deff lower the psi, never inflate them to wut the sidewall says, that MAX psi not rec psi.
    and raise the front some
    Save ur engines!
    1010011010 Atlblkz06's Avatar
    Hell
    High tire pressure = bouncy tire = high wheel hop.
    I dont know anything about your car so take this with a pinch of salt:
    Lower it by 20psi for drag launches and you'll see a big change IMO
    thanks guys. my car is not slammed like other hondas i keep it about 1 inch of wheel gap in the front and 1.5 wheel gap in the rear.....to me why slamm it when you have nice stuff you worked hard to get and then fuck it up on speed bumps...etc....its just another honda trend that you have to do.....
    my momma's house
    Yea, Long doesn't really have is car stoopid low. I'm willing to bet that its a combo of the tire pressure being too high, and that toe issue. With your added weight in the front, make sure your not getting any coil bind, but like I said, I don't think your car is even low enough for that issue.
    Trend settin'
    sup J, yea i bet its just the tire pressure like what atlblkx06 said, "High tire pressure = bouncy tire = high wheel hop."
    my first time having something smaller than a 50 series tire, i got an allignment already after i just installed my camber kits, so camber, caster, toe is perfect.....so let me try lowering the PSI on it
    FUK IT! bowdown201's Avatar
    Next Door
    If that doesnt help your problem you may wanna check into you axles..ive heard of H2B's not properly being installed and binding axles..just a suggestion though
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Dude first off your tire pressure is way too high. Lower it to about 30-33 psi. Then get your camber and toe adjusted. Then get you some prothane motor mount inserts. The inserts will take care of 95% of the wheel hop. Not gonna lie and try to explain exactly why but it just does. Ask anyone who has them. Only downside is you will feel some engine vibration in your steering wheel but it is better than breaking axles.
    Apr 2009
    Dude first off your tire pressure is way too high. Lower it to about 30-33 psi. Then get your camber and toe adjusted. Then get you some prothane motor mount inserts. The inserts will take care of 95% of the wheel hop. Not gonna lie and try to explain exactly why but it just does. Ask anyone who has them. Only downside is you will feel some engine vibration in your steering wheel but it is better than breaking axles. Sorry if I repeated myself. I didn't know if the website posted my last reply cause I had to go back cause the screen was froze after I hit the submit reply button.
    Quote Originally Posted by TSiFTW
    i have stiff hasport mounts already engine doesnt move and i already have vibration throughout the car, so lower the pressure to 30-33psi and than go get another allignment? this is a daily drvier so i would rather do an alignment on the regular tire pressure for everyday driving intead of aligning it to the track only...
    There's a really easy and simple cure to wheel hop, it doesn't even cost a dime...
    Stop spinning the tires. I promise you'll take tenths off your 60' time.
