Results 1 to 14 of 14
Thread: Small block 350 ?'s
    ///M :) wannab20hatch's Avatar
    Default Small block 350 ?'s
    Ive done the whole honda thing and now i want to build a nice older truck. Im new to v8's. Anyone got any good sites to check out for info? Like whats better 2 bolt main, 4 bolt main. Crate vs. Rebuild a junkyard motor. hydraulic lifter, solid lifters.
    Any help will get you reps
    Build 42% Done ACCORDPRIDE's Avatar
    In a pile a H22 parts
    4 bolt main is better
    crate is better if you can afford it
    hydraulic and solid depends on the cam you want to run in it really
    AKA HIZDAWAY
    \m/>_<\m/ dorin48's Avatar
    Canton
    Quote Originally Posted by ACCORDPRIDE
    Yep. You will see higher prices on 4 bolt engines than the 2 bolt.
    aspiring racer
    Le Grand, Ia
    i would pick up a junkyard motor and go from the bottom up, learn alot, appreciate it more, feel damn good when your done
    Thats what i was thinking. Plus ill know whats in it and everything. Whats a good year model to get one out of? Truck,car? ive heard the marine motors have an iron block and can take alot of abuse. any truth to that?
    Canton
    Unless you get a high performance or one thats not very old then it will have an iron block already. I dont know when the switched to aluminum but if your going carb'd 99% of all were iron block.
    ok cool. yeah im definitely going carb'd. IMO you cant have a kickass old truck w/o a carb
    Woodstock
    I'd try to get a mid 80's truck block, most trucks had 4 bolt mains(they also had 305's make sure you get a 350). The solid lifter vs. Hyd. lifter also depends on your budget, solid is alot cheaper . I'm going with a 350 bored .030 over with 6 in. rods and a 3.480 stroke crank and a flat tappet cam with soldi lifters with my junkyard rebuild. Heads are better to get aftermarket if you want power (vortecs are nice but req. the vortec intake and such), then a good intake and 4 brl. carb and you should be good to go. Also the iron block is fine, but I'd get Aluminum heads.
    Banned flak_monkey's Avatar
    Atl
    I just wish I could get a transmission that fucking worked. Jesus nobody fucking makes a 4l60e that works. I hate this z28.
    2 bolt mains converted to a 4 bolt main is a lot better than a straight 4 bolt main. Also if I were in your shoes I would just go ahead and build it yourself. Much more satisfying and you know exactly what is done to it and the quality of work done into it(unless you have no clue what your doing). Also do a stroker, if your patient you can find a great deal on stroker parts, hell they are pretty cheap new also.
    Woodstock
    The stroker parts usually cost just a hair more then the other parts anyways, might as well buy them if you're looking for performance.
    aspiring racer
    Le Grand, Ia
    a shop I used to work for had a iron block 6.0 liter and put ls interanls and heads. couple of turbos and it was 980 hp on the dyno I think it was a 6 speed 4wd avalanche
    Middle, Ga
    Personally, I would go with a small block rather than a big block any day of the week. Alot of people go with sb350 but I like sb400. I would build it myself, how I want it before I bought a crate motor. An old used chevy block isn't hard to find at all and it will probably be a tad cheaper depending on what exactly you're wanting to get out of the motor. And as stated above, might as well go ahead and build a stroker. For the few extra bucks, you get better HP. As for 4 bolt or 2 bolt, my dad and I have always went with 4 bolts. Always been pleased. Goodluck with whatever you decide to do.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Quote Originally Posted by flak_monkey
    I can make it work.
