Thread: 97 Blazer will not start
    Default 97 Blazer will not start
    Swapped the engine in my 97 Blazer, Vortec 4.3, and it will not start now. I have double checked and rechecked everything, all sensors and wires are connected. It will run great with gas sprayed in the intake, starts right up, no CEL or anything. Have fuel pressure getting all the way to the spider injection system, injectors arent firing. All fuses are good also.
    Any ideas as to what to start checking or what controls the injectors?
    BMW 750iL
    swap the spiders out for a know working 1. i did a swap for a lady 2 years ago. i was going to change while it was out of the car. long story short i didnt no fuel. swapped it an bam it worked again.
    Quote Originally Posted by no mo hondas
    Done and still nothing. Funny thing is it wouldnt start on its own before, always had to have a shot of starter fluid. Thinking fuel pump too.
    BMW 750iL
    How mych fuel presure these engines has to get plenty of gas like almost near 50ish PSI or better
    It sounds like the fuelpump though. Never had a issue with the fuel injectors an not a known issue with these.But that fuel pump is OH MY GOD POS!! with all newer GM's
    the fuelfilter/pump needs to be changed
    LAWRENCEVILLE
    was it working before you swaped the engine? check every thing before you start swaping stuff. relay,fuses,do you hear the fuel pump whine when you turn the key on?
    Hella stock member!
    It was but something wasnt just right. Had to spray it with starter fluid to get it to start then it would stay running. Got fuel to the lines, pump is working. I think the pump is bad. Not enough pressure, Im getting a gauge today.
    BMW 750iL
