Thread: 92-96 Prelude Fog light wiring write-up.
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Exclamation 92-96 Prelude Fog light wiring write-up.
    i found this while i was looking how to wire mine.helped me quite a bit, so i figured someone may need it.
    whats needed:
    12-14 gauge wire
    wire cutters/strippers
    assorted connectors and wire taps
    electrical tape
    For the most part this is a pretty easy project if you can follow the diagram and strip and connect wires.
    besides following the diagram there are only a couple little things to be aware of.
    1.)make sure that you just tap into the positive wire of the corner light. do not just directly connect it to the relay,or your fogs wont turn on and neither will your corner lights. the relay uses the power from the light to turn on the fogs.
    2.) i would recommend that you put at least a 20amp fuse in between the battery and relay for extra protection. if the 20amp blows then a 30amp fuse might be needed. most relays provides protection up to 40amps.
    3.)if you have an OEM fog switch you can wire that in between the corner light and relay. but when wiring the OEM switch it has to be wired a certain way or the light on the switch will always be on. (look at second diagram)
    4.)when wiring the OEM switch there are 3 wires coming off of it
    black=ground
    red=goes to positive of corner light
    orange=goes to relay
    i will double check on the red and orange wire b.c i did this a while ago and im going off of memory
    without switch
    with switch
    buford,ga
    yeah i wrote that up.... your welcome a little acknowledgment would be nice since i posted that on a different site
    94 si h23a1
    GPC member #2
    Senior Member StreetHazard's Avatar
    Sep 2008
    BLAM!
