idle screw on the throttle body. you need a small screw driver but i would check for vac leaks first to makes sure its not that first. most likely its a vac leak. theres not that many vac lines on those year accords and there right in sight so it shouldnt be to hard. check for torn hoses and even in the back of the intake manifold there should be 2 plugs. check those to. you can use brake cleaner and spray on the hoses and if you do have a vac leak the brake cleaner will make it idle funny for a sec and if that happens then you know you have a vac leak
