Results 1 to 23 of 23
Thread: civic clicking
    Need Parts!
    Canton
    Default civic clicking
    ive looked at some post but they arent exactly the same. my car makes a click when you let off the gas. i dosnt click in turns, stops when i push the clutch in, and i adjusted my valves maybe 4 days ago. could it still be cv?
    lol could be alot of things
    step sticky stephen's Avatar
    if it stops when you press the clutch, then it probably has nothing to do with valves/cv axles/etc... that'd sound more like a throw out bearing issue.
    Quote Originally Posted by EthanR
    thats a sound thats hard to diagnose over the internet u might want to get it to a shop.
    gone old school C-loS109's Avatar
    somewhere
    well maybe its the transmission. go to a shop.
    =EJ-EG SQUAD SUPPORTER=
    2000 HONDA CIVIC - SOLD
    1966 MUSTANG COUPE - TRADED
    1989 FOXBODY MUSTANG - DD
    Need Parts!
    Canton
    ive been wanting to but im short on time. it has a newer throw out bearing (put in when i swapped the motor 2 months ago) but it was noisy
    Thanks for the help!
    check ur motor mount..never mine. u said it stops when u step on the clutch meaning its continuous. yeah u might want to get that to a shop asap.
    JDM TYTE AnthonyF's Avatar
    Cumming
    ^true. Could be a broken mount and the engine is rattling on the metal. Who knows. Def take it to a shop though.
    -Ant.
    The Carbon Fibered R6
    Need Parts!
    Canton
    this may be a dumb question but do shop charge to look at something? b/c ill be screwed if so
    depends on the shop and how far they get into looking at it.
    Hiram GA
    I think most shops will charge an hour worth of labor just to do a diagnosis.
    But most of the time, if you let them do the repair, they will diagnose it for free.
    usually if its a parkinglot diag they dnt/cant charge u for that bc theres no paper work and u still have ur keys. lol!! if they say leave it with us, get ready to spend.
    Need Parts!
    Canton
    i got a friend that is workin at a shop ill try to get him to cut me a deal.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    i say mount in tha back takes most abuse, and when your under a load then let it coast it shifts back in the cradle and if it stops when you mash the clutch is cause it has no load on it at all ne more.
    Augusta Ga
    check throw out bearing .....
    93 sol Si
    95 sol S
    95 sol Si
    Hamilton, GA
    x3
    another thing, did you go with a lightweight/aftermarket flywheel and/or aftermarket clutch? if so, you might be getting a little flywheel chatter. my car came with a dual mass flywheel and unsprung clutch. i replaced it with a lightweight flywheel and another unsprung clutch, and it chatters like hell when the clutch is released. if that's the case, there's not much you can do about it...it MIGHT go away when it gets fully broken in.
    Need Parts!
    Canton
    dont think so it may sound stupid but it the noise reminds me of a card on a bicycle lol
    Quote Originally Posted by stephen
    Wheres it coming from?
    Usually it's easier if you can tell where its coming from. Under the hood? Wheelbase?
    Should be easy to at least eliminate some choices like that. CV vs a flywheel or a throwout bearing.
    Need Parts!
    Canton
    id say the middle because i can hear it on my side and the passenger can hear on there side to
    blank
    nowhere
    if you let me paint your VC prob would fix it
    Worked for me! Thanks again Bucky!
    Lexus GS300
    Need Parts!
    Canton
    would love for you to do that but im poor and have to paint mine myself lol
