Results 1 to 8 of 8
Thread: My hatch Wont start now.
    Norcross
    Default My hatch Wont start now.
    So I was drivin my civic around the other day and it shut down n wont crank anymore. The ecu was on the wall n fell as i took a turn (im not sure if the car shut down before or after the ecu fell) But earlier as i was driving, the fuel pump was humming extra loud and it doesnt hum anymore while the key is in the On position. any suggestions?!
    ecu, main relay, fuse, or fuel pump.
    Senior Member Schugg's Avatar
    what year is your civic? if its not a fuse/relay find where your fuel pump bolts up from inside your car, usually under the back seat cushion right at the edge of where the trunk starts. once you find it (has a wire form in the car going into an aluminum looking cover), have someone try to start the car while you hit the fuel pump area with a mallet or something that wont cause damage but can jolt the pump around good. if it starts your pumps going out.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Norcross
    problem fixed. thanks n reps to replies
    so what was it
    - 2008 Acura TL-S
    Norcross
    it was the fuse for the ecu. but it now keeps popping. i made another thread about it reps to u guys
    oooo
