Results 1 to 18 of 18
Thread: how long to work in a sr 20 det blacktop
    Default how long to work in a sr 20 det blacktop
    how many miles should i drive so don't **** somthing
    up
    co-lame-bus
    what ? try again, this makes no sense....
    Newbie Photodude RBS's Avatar
    All Over U S A
    0, if you dont drive you wont fcuk anything up
    is it rebuilt?
    Athens/ATL
    If it's just a stock one that you got from an importer, it's been broken in lol.
    YEAH! bRiAnMcIvIcS's Avatar
    What???
    Earth
    No more than 5 one way. I drove 64 miles round-trip in my redtop everyday for a year... I can't tell you how many times the canuter valve hit the tressel rod and caused a left-handed smoke shift pattern. Keep it to about ten miles a day and heat build-up shouldn't be a problem.
    lulz
    JDM TYTE AnthonyF's Avatar
    Cumming
    The word "nerd" was first coined by Dr. Seuss in "If I Ran the Zoo."
    The plastic things on the end of shoelaces are called aglets.
    -Ant.
    The Carbon Fibered R6
    I drive my redtop 60-70 miles a day everday and it does just fine
    Athens/ATL
    I drive my pinktop 88 miles a day at 87 mph so that my flux capacitor doesn't kick in and send me to a time before IA
    Duluth, GA
    repd
    Out in the Boonies
    billygun
    IA.COM NOOB Join Date: Feb 2008
    Doesn't surprise me.
    Senior Member BlueHatch's Avatar
    Green Acres
    here
    Attached Thumbnails Attached Thumbnails -suicide-jpg
    Earth
    Ya'll are mean. As long as the Cam gear timing is turned back .45 degrees with a 25mm spacer he should be fine.
    ATL, GA
    I am such a noob for not knowing what the spacer supposed to do...
    But, the truth of SR engine is that it is weak as hell and really sentative that you can only run it when it is the perfect time during the day which is 4:20 for as long as you want.
    The other myeth is that SR engine run so bad in Japan that the Japanese put KAs in the 240sx and like all their other cars during the 90s. So be warned.
    suk it
    roflcopter V-Spec II
    Norcross
    What the fuck is going on in here? Closed.
    OP: Make another thread, but be clearer. Is it rebuilt? Did you just build the motor? Did you just put the motor in the car? What car is it in? What exactly is the motor? Technically the S14/S15 motors are blacktops as well as the later S13 ones.
