Speedometer is stuck at 20 mph no matter if I'm at 0 or 80 and all places in between...this sounds like the VSS right? where can I find a cheap one?
 Speedometer problem
 Speedometer problem
				is it stuck there even when the car is off
				no just when the key is turned and when cranked up
				go to the vss and unplug it and see if it drops. are u getting a cel.
				i unplugged it and it sits at like 15 instead even when cranked or key turned
				i do have a cel but its o2 sensor
				have u tried swapping clusters
				no one to swap with and I'm not gonna buy another one just to see if that's the problem
				i think that the vss usually cuts the tach out. so does it still work?
				it doesn't just sit at 0 but it sits at like 18 mph no matter what. like 1 out of ten times I drive the car it works normallyOriginally Posted by joshk5145
				maybe a short in the wiring or something. id swap clusters and see if it just the cluster also.
				i had a problem with my speedo in my 93 hatch. worked sometimes and sometimes it didnt but all i did was find a car in the junk yard and pull the cluster. take the cover off the front and there should be 3 screws holding the actual speed part of the cluster in just take those out and change that part. its alot cheaper than the whole cluster
It is said that something as simple as
the flutter of a Butterfly's Wing can
ultimately cause a typhoon halfway
around the world.
-Chaos Theory
				keep it, if you were to get pulled for a speeding ticket, just tell the cop you were going to a mechanic to see if you can get it fixed
--Crazed Impressions
				f uck that. dont speed no ticket. that problems solved.Originally Posted by Hayes21890
i still think its something in the cluster/gauge its self.
