Results 1 to 14 of 14
Thread: Speedometer problem
    Duluth, GA
    Default Speedometer problem
    Speedometer is stuck at 20 mph no matter if I'm at 0 or 80 and all places in between...this sounds like the VSS right? where can I find a cheap one?
    is it stuck there even when the car is off
    Duluth, GA
    no just when the key is turned and when cranked up
    go to the vss and unplug it and see if it drops. are u getting a cel.
    Duluth, GA
    i unplugged it and it sits at like 15 instead even when cranked or key turned
    Duluth, GA
    i do have a cel but its o2 sensor
    have u tried swapping clusters
    Duluth, GA
    no one to swap with and I'm not gonna buy another one just to see if that's the problem
    Certified Gearhead joshk5145's Avatar
    Greene/Athens
    i think that the vss usually cuts the tach out. so does it still work?
    Duluth, GA
    Quote Originally Posted by joshk5145
    it doesn't just sit at 0 but it sits at like 18 mph no matter what. like 1 out of ten times I drive the car it works normally
    maybe a short in the wiring or something. id swap clusters and see if it just the cluster also.
    Certified Gearhead TrickcitykustomsPrez's Avatar
    Blue Ridge, GA...AKA BFE
    i had a problem with my speedo in my 93 hatch. worked sometimes and sometimes it didnt but all i did was find a car in the junk yard and pull the cluster. take the cover off the front and there should be 3 screws holding the actual speed part of the cluster in just take those out and change that part. its alot cheaper than the whole cluster
    It is said that something as simple as
    the flutter of a Butterfly's Wing can
    ultimately cause a typhoon halfway
    around the world.
    -Chaos Theory
    Crazed Impressions
    Winston-Salem, NC
    keep it, if you were to get pulled for a speeding ticket, just tell the cop you were going to a mechanic to see if you can get it fixed
    --Crazed Impressions
    Quote Originally Posted by Hayes21890
    f uck that. dont speed no ticket. that problems solved.
    i still think its something in the cluster/gauge its self.
