Results 1 to 10 of 10
Thread: Camber Kit/ Strut question.
    Athens
    Default Camber Kit/ Strut question.
    So, I am putting new struts on my Talon, and also camber kit all the way around. My question is, should I put the struts on before the camber kit? I haven't ever messed with this before, so thanks in advance for all serious answers.
    2013 Dart 1.4T 6MT
    boooooostin'
    got air? Bud's Avatar
    northside
    haha i wish i could help ya bro.
    True DIYer happysol1982's Avatar
    Branson, MO
    Put it in at the same time. That way you don't have to take things apart multiple times. Just do it all at once.
    70hp FTL StraightSix's Avatar
    Central, SC
    It depends. Will the installation of the parts you have lower the car any? If you aren't changing ride height, then you shouldn't need a camber kit. Also, on some cars all a camber kit is is an eccentric bolt that changes the angle of the knuckle. If that's all your camber kit is then I wouldn't install it until getting the car on an alignment rack and determining the need for more or less camber.
    Athens
    thanks guys, to answer the question straightsix, my car is already lowered, and the back tires lay in at the top pretty bad. I have had the car maybe two months with new tires, and they are already wore out. So no, it will not lower the car anymore, I just want to correct the camber issue.
    2013 Dart 1.4T 6MT
    boooooostin'
    Quote Originally Posted by Double_0_Rusty
    lol you cant lower it anymore and did you get tires yet?
    banned mother fucker
    far away
    but camber kit on while you put you new struts on, all at the same time, then right after you do get it aligned right after. with camber kits, i know when i put mine on it was way way off, so get it aligned right after you install them or your tires will be bad. so install struts and camber kit and align same day
    Kennesaw, GA
    Is it just the inside corners of your tires wearing out? If thats the case, you need to get on an alignment rack to check the toe-in. thats usually your main problem
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Central, SC
    ^^ On a car with stock ride height that is usually correct. However, extreme camber angles will cause excessive wear on the tires edges also.
    Anyway, the short answer to the OP's question is yes, install the camber kit when you do the strut install. Then, align.
    Athens
    Quote Originally Posted by StraightSix
    Thanks, yeah the car is literally slammed now. I am going to do it all at the same time, and I have camber kits and tires on the way, car should be back on the road next monday.
    2013 Dart 1.4T 6MT
    boooooostin'
