Results 1 to 10 of 10
Thread: ls vtec torque spec
    turbonetics
    Default ls vtec torque spec
    i need help with torque spec on rod bolts and main bearing bolts ... also need head bolts spec on a ls vtec with gsr arp head bolts..
    dfafa
    Quote Originally Posted by k20
    it would be the same as the book says. look it up. its not as hard as you are trying to make it. they are not different. gl.
    Jonesboro/Stockbridge
    you mean ARP head studs? those you're suppose to tighten into the block hand tight, so use the allen key and tighten and when it gets tight, turn it a 1/3 of a turn counterclockwise so it isn't too tight. And just tighten the nuts on the studs the same torque spec.
    turbonetics
    i just need some numbers ...
    dfafa
    look it up. just use the stock torque specs.
    Newbie Photodude RBS's Avatar
    All Over U S A
    if your using stock LS rodbolts and mainbolts . . its going to be Mainbolts ( 51 lbs ) Rodbolts ( 23 lbs ), arp headstuds for GSR? hit up arp and see the process of installing them
    ek hatch
    Macon
    ^^the first person to actually answer your question, reps for joo
    97ek hatch
    All Over U S A
    lol i mean seriously, all he asked for was some silly numbers
    ARP HEadstuds are 70 ft/lbs
    Mains IIRC is 51ft/lbs
    Rod Bolts should be 29ft/lbs if they are ARP
    Northwest Georgia
    main bearing caps torque to 56 ft lbs in b18a/b
