Ok I know that if do a suspension and brake conversion on my 96 EK coupe from my Integra I have to change this one part, I do not know what its called but it looks like a brake fluid hub, its right there on the firewall left and down from the master cylinder.
Here is the situation, the civic "hub" has 5 brake line connection while the integra has only 4 and they are also shaped diffrently.
If I want to properly utilize the four wheel disc brake swap I know I need to change that one part.
But since these two hubs are not compatible, where do I get the right one?
I am thinking I need the fluid 'hub' from a 99-00 Si, but I am not sure.
does the Si have four wheel disc brakes? And is that hubed shaped the same as it would be on a 96 ex coupe?
Ok so I found out that that thing is called "proportioning valve"
so which one do I need to get to make my disc brake conversion operate at optimal capacity?
JJSPEC.COM
 Thieves)
[/URL]
