Results 1 to 29 of 29
Thread: car wont rev over 2500rpm!!!
    Southside of The Jungle
    Default car wont rev over 2500rpm!!!
    Ive got a civic with a b18 and like it only does it somtimes but i dont know what it is like the other day i tried to drive it after it rained the ground was wet but not like alot of water it had mostly dried up but i drove my car down the street and as i was drivin back it wouldnt go over 2500rpm and if i let off the gas it would idle i had to keep dumpin the clutch to get it back to my house somone told me it could be the tps i checked the filter its good i checked the wires to the tps there good help me
    moisture in your distributor cap. take it off and look for moisture, if it's in there wipe it out. thats one possibility
    Valet mode? Hah just messin.
    02 GSX-R Telefonica Movistar
    99 Prelude
    95 Mustang GT Vert
    98 Mustang 3.8
    itakepictures
    changaroopouch
    limp mode?
    yea but my car was parked in the garage while it was raining so i dont think anywater got inthere but i will see
    Quote Originally Posted by ekcivic9
    limp mode?
    wat
    i'm not talking water necessarily, sometimes a small crack in the distributor cap can allow moisture to get into the cap and cause that issue
    only reason i mentioned that was because you said that it rained and the acceleration issue, and that reminded me of what my problem was, or moisture in your spark plug hole.
    i had both issues at once on different occasions and the problem was solved both times.
    just go check it, it only takes a minute to check the distributor cap for moisture
    ok i aint get a chance to today i went to summit for the mustang drive in but i will check it out
    nope there was no moisture in the distributor cap whats next
    Blooregard Q. Kazoo turbosx©'s Avatar
    femalesaplenty
    unplug your tps and see if that fixes it.If that dont work check your ignition system condition.
    I got dinner to goto.
    Quote Originally Posted by SE-R_Killer
    wat you mean unplug it if u mean un plug it and plug it back up i tried that and like when i try to rev the car it sounds like its hitting a rev limiter and bounces at 2500
    any cel?
    Privateer Racing!!
    Duluth,Ga
    I think its just sick, of that nasty ass intake you have on it!!
    Quote Originally Posted by B18c1Turboed
    damn that might work if i didnt try that alreadi it worked the first time but not the second
    femalesaplenty
    no take the tps off and drive it.It will jus defaulf to wide open throttle.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    your car could be in safe mode, try another dizzy and that "Should" fix the problem.
    Shit happpened to my REX while driving on the highway
    got damn i just got that distributor wasnt new but better than the old one since it locked up i wonder do they got a core on these shits
    we all drive ferraris
    in a house
    nice intake. lololol
    Behold...it's slow
    oh how u take the tps off cuz when i went to autozone they said it has rivets or some shit like where it isnt bolted to the tb they didnt even have the sensor anyways so i was like fuck it
    3 Cylinders of Fury
    Quote Originally Posted by CRACKaLACKIN
    +1
    The dryer wants its ducting back!!!
    Augusta Ga
    dremel tool is your best friend when fooling with the tps ! ... u cut slots in the rivets and take a flat head screw driver and unscrew them !! then replace with a screw incase further problems occur .... i remind u put the tps back in same place as u take it off or mess with it a lil while the car is cranked if the tps doesnt make the idle fluctuate bad/better ... id replace TPS .thought id look out .. and g/l
    93 sol Si
    95 sol S
    95 sol Si
    Quote Originally Posted by VteckTuna
    +1
    fuck dat it aint gettin it back i figured if it works for the dryer why wouldnt it work for my car
    yea i got a check engine light on figured it was the oxygen sensor fucking up or somthing but somone said it could be the tps thats making it fuck up and could be the tps makin the check engine light come on
    No
    +1
    LIRL.
    Dryer exhaust for an intake!!
    Quote Originally Posted by RobbieDB
    LIRL.
    they sell em at autozone i dont kno where mine came from it was on there when i bout the car so i said fuck it it can be a short ram or a cold air somtimes when i feel like i wanna hang i jus lift the hood and let it hang over the fender so i can show the ladys wat im workin wit
    check the code to find out what's the problem instead of chasing your tail. go check the code and report back what it is.
    idk kno how to check the codes but on the ecu i got 7 blinks my friend checked it out and he said its the tps so i took the tb off wanted to know is that right
    man i jus disconnect the shit i turned it on and first it wouldnt idle i knew it was but after like 2 mins its idled on its own with the sensor disconnected so my friend told me i gotta get a new one where can i get the sensor from and are those interchangeable
