ignition timing then. you said you had to drill the dist. bracket? t take it you had the distributor off then. check to see the firing order is in time with the pistons. if the #1 piston comes up on exhaust and you are getting your spark, then the thing won't run. if it's getting the spark on the intake it won't run. spark needs to be on right stroke. set #1 to TDC. can see on the crank pulley usually. then set the distributor to fire on #1. set everything in there, try to turn it over as long as there is compression, spark, and fuel it should run. assuming everything is in time with eachother. LMK. if you need more help message my phone. 404-324-2390.
