Thread: tranny go shake shake shake!?!
    F.T.W.K.T.A.
    Dalton
    Default tranny go shake shake shake!?!
    ok like the title says i need BIG help with a tranny problem.. my tranny will not go into gear and when i can force it into gear the whole car shakes until i start to go.... i have had some one tell me it was my clutch not releasing there for my release bearing was the problem and someone else told me my shift forks were bent/warped, and another said my pressure plate diaphram springs took a dook.. it also started then i changed my clutch and pressure plate. i changed the pilot bearing but reused the release bearing.... i also looked at my release fork and it seams to be crooked...... any help before pull/drop the whole engine/tranny to take-a-look-C. thanx in advance to the people who are able to help, whatever info is much ablidged
    94 civic Dx 4dr - N/A Ls/Vtec
    94 Del Sol Si - Project O'SH is GO!!!
    91 Accord Lx - Totaled
    Just another ricer
    Pennsyl-fuckin-tucky ya'll
    Quote Originally Posted by kain86
    Shift forks..lol..AKA Non moving parts unless your actually shifting it. Deffinetely not the issue.
    What Kind of trans is it?? Whats it go in?
    I could see it being a bearing you didn't change. However, did it do this before you replaced the clutch? If not, you may have peckered something up in the change. Possibly bent the fork and its riding on the clutch and forcing it to wobbble. If thats the case its going to ultimately ruin a lot of $ worth of shit. Your you could've gotten a defected bearing (the one you replaced)
    Was there anything else you might have done that would cause this?
    90% of teens say "oh shit" before a wreck. The other 10% are from Pennsylvania, they say " hold my beer and watch this shit."
    EvasiveEF9: Just fill me in...if it's black, I'm all over it...
    F.T.W.K.T.A.
    Dalton
    it's a s20 d-series tranny, and it only does it when the car is on and i try to shift into gear
    F.T.W.K.T.A.
    Dalton
    ok new revalation i just tried to go to work...... before i started the car i was able the shift through the gears no problem, so i tried to start it in first gear... the car started shook then shut off so i started it again but in neutral, then tried to get it to go into gear and it was like trying to push through a concrete wall, so now it's down to release bearing and pressureplate, if it's the pressure plate does anyone know where to get a stage 3 pressure plate only and not a whole kit.
