Results 1 to 34 of 34
Thread: Full Throttle Shift.
    Ohio asshole.
    Default Full Throttle Shift.
    How exactly does it work? Does it completely shut your car down? Or just stop spark while the rest keeps running?
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    Are you talking about powershifting(racing)?
    Ohio asshole.
    Talkin about shifting and never lifting. As in chipped ECU hit the clutch and it shuts it down while your shifting.
    Da "A" Niccuh
    IDK Know about the spark or anything but i know if you do it wrong. Kiss you tranny good bye. Very hard Technique i still want to learn.
    Ohio asshole.
    Quote Originally Posted by twinj
    I can some what do it as it. But I'm talking about how they chip the ECU so there is no doing it wrong. It kills the RPM's for a split second while never letting off the gas.
    Da "A" Niccuh
    Wouldn't that mess up the engine if you think about it. All of the internals are still in motion but no spark. Not a Guru or anything ain't that somewhere near the lines of detonation or a really bad misfire.
    Ohio asshole.
    Somewhat. If you think about it though. Your on the clutch, therefore your car rolling is not turning the engine and its losing RPM's (like its shutting down) Having said that, then turning your car off in general would be bad for your motor too.
    warner robins
    JJSPEC.COM
    Ohio asshole.
    Quote Originally Posted by d16_turbo
    Thats in a sense what I was looking for. Was it just a button to be hooked up and mounted to your clutch that shuts the engine down.
    More so what I was looking to find out was could I do it w/out a chipped ECU. Unless I'm missing something. It's something you can do with out the ECU being chipped. WOuldn't work AS efficient..but would work none the less.
    With the time it would take to shift, the motor wouldn't even have enough time to shut completley down before you'd be off the clutch, it would be running again, and be revving back up before your clutch is completely engaged. Not really adding strain to the transmission or motor.
    Quote Originally Posted by jmmx258
    "no lift shift" is normally an ignition kill. If i'm not mistaken you can do it with Crome...i know you can setup multi-stage launch control & rev limiters so i'm sure an ignition kill wired to a switch on the clutch would be relatively simple.
    ...BUT you don't need it and won't ever need it. You can build that B16 up to Toda spec for $12,000 and it still won't ever be needed. Your money could be spent on literaly 100,000 other things...like a quality light weight flywheel, clutch & pressure plate, LSD, head work, quality header, fuel rail & pressure regulator w/ tuning, etc.
    Ohio asshole.
    I know I know lol. I just think it'd be fun to be able to do it. Hell I know I could do it for a 10 dollar button from the parts store. So I mean. It's not like i'll be breaking the bank ya know?
    Plus..if it doesnt work out, i'll take the button back lol
    What is a "button" going to do?
    The clutch will have to have a switch on it, similiar to a starter kill switch, except wired to the ignition to temporary kill the power from the distributor to the sparkplugs...any idea what happens if you don't have it perfectly timed? It might need to be 1/10 to 1/100 to 1/1000 of a second...what happens to a piston and rod if there isn't an explosion forcing it back down when you're running WOT or what if it cuts back on when the piston is coming back up?
    southside
    i seen someone do that in a 2000 civic si on the interstate no liftin but we was movin i heard u can powershift like dat sometimes but not good to do all the time like my friend he said he jus do it like when he needs to but then he found out if he does it wrong it will fuck up the flywheel
    Ohio asshole.
    Quote Originally Posted by corey30349
    If he thinks he NEEDS to do it on the highway, he's an idiot. I just wanna do it b/c it would be fun to have.
    I can do it w/out it shutting down, but I can't stay completely in the throttle. I gotta roll off about half way which works fine, but I'm sure it would be better to be able to stay WFO.
    warner robins
    i would just get hondata s300
    JJSPEC.COM
    Ohio asshole.
    Easy to say. Easy to do as well..if you have the money.
    warner robins
    thats the only problem
    JJSPEC.COM
    banned from heaven..
    i know how to do it. but have never done it on my WRX. to dangerous, i might break my tranny.
    Ohio asshole.
    Quote Originally Posted by Maniac
    Lol yeah. You should think about a honduhh! lol
    HELL NO! cause unlike yall, i have TQ! right now with the little mods i have i should be @ 280awtq!
    what do you have? L0L!
    Has A slow car RUSH's Avatar
    No, you will make fun of me then
    lol at the 280awtq.....WOW!
    I never even let off the gas in my car through the 1/4...haha
    Stupid Auto Supra, thats what I drive, And You Can
    BUY MY CAR HERE
    www.mountainboost.com
    www.180pix.com
    Quote Originally Posted by RUSH
    haha, what car do you drive?
    BK ALL DAY
    i have done it a few times... and if u wanna do it with out a problem get hondata like D16 turbo said. i have done it in my buddies rsx with hondata and that shit hits very nicely..
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    w/ hondata, crome, etc it sets a temporary lower rev limit based on a fuel cut if the input (clutch switch is activated by pressing the clutch). if it sees that then it lowers the rev limit to a preset amount.
    say your regular limit is at 8500rpm (that's typically fuel cut like on a stock ecu unless you're using something else or msd which cuts ignition-hence fireballs out the exhaust). w/ the fts you can set it to cut at 6k rpm so that when you step on the clutch your revs will never go above 6k no matter how deep on the gas you are.
    if you can shift quick enough you can flat shift at the track, but you will bounce off the normal rev limiter if you can't do it fast enough or risk grinding into gear if you hand and foot aren't timed well.
    Ohio asshole.
    I need to find out my rev limiter. I have my shif light set at 8500 right now..and it never skips a beat when I shift there or just past it.
    Let me drive your car and ill show you how to do it.
