Quote Originally Posted by GermanMuscle
i think the radiator has a small hole or a crack. is there some way of fixing it or do i have to replace the whole thing. right now the system wont buld up pressure on the cooling system. i have no idea what to check or replace.
oh and the car does NOT overheat
reps for whoever gives me the best answer or the first good answer
There is a Pressure Tester that you can buy, This will help you to find the leak, And it Depends were the leak is... If its in the core you can fix it.. But if the Plastic is crack it would be worth just buying a new one cause the repair kits will never hold up...
