Results 1 to 15 of 15
Thread: QUESTION ABOUT CLUSTER
    Default QUESTION ABOUT CLUSTER
    well for some reason my cluster isnt working no more, did a burn out hahaha and now, rpm, gas, and temp meters dont work no more....please tell me if anyone has ever had this situation before
    Sleeper... I <3 my EF's Avatar
    Valdosta...
    Check fuses. Never had this problem but that might be the solution.
    nope...all fuses are good, speedo works becuzz if runs a cable line lol....rpm is dead, gas meter, temp meter dead, dosnt work, only light i see when turned on is the cluster light, and battery light, no seat belt light, no check light and timer also and signals are not working but if i press the emergancy it turns on only....help me out fellas.....!
    far far away
    Check your grounds, especially the one above the hood release.
    have you checked the plugs on the back of the cluster? One of mine fell out one day out of nowhere and caused the rpm and a few other problems.
    Quote Originally Posted by jfrolang
    ummm never thought of that, ur talking about the ground for the fuse box it self correct, if so i didnt, im going to check that out.
    Quote Originally Posted by Mad Mike
    yeah i thought that was the problem, i checked it out first thing but it wasnt it, like it was working perfectly fine, only thing i remeber was doing a burn out take off and then parked the car and next day going to work, rpm is dead, my turn signals wouldn't go on.............im thinking it has to be a loose wire or a wire touch ground somewhere under the dash and fuse box.
    ttt
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    pull the cluster and and look at trace the wires and see if any are burned out.
    well i figure the cluster is dead old, found out a buddy of mines went through the same problem and he switched his with another one......so now anyone got one for sale holla back...!
    Snellville/Statesboro
    ^ i got one w/out a tach, but it's in mint condition.
    UPROOT Photography FTW
    I had the same thing happen to me not long ago, turns out one of my turn signal wires had rubbed and shorted against the body.
    please let me know how u fix it
    pm sent
    cluster was bad, got a new one thanks everyone
