Results 1 to 22 of 22
Thread: Painting tips?
    Norcross
    Default Painting tips?
    Just got my compressor and spray gun. I'm a pure noob to laying down paint, so anyone feel free to give me some pointers, such as how much paint will be needed, ratios to mix paint/condenser clear/hardener, Sanding steps? Thanks in advance!
    Kennesaw, GA
    Since you probably don't have a booth, it'd probably be a good idea to wet the floor where you're painting to trap some dust. It'd also be a good idea to make your own makeshift booth.
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Norcross
    yea i dont have a booth, but i guess i'll look into building a cheapo one. Thanks, any other tips greatly appreciated, or if anyone wants to lend me a hand in person
    Jan 2011
    sand down the clear coat with 1500 wet sandpaper..... the paint you can either mix it half paint/ half reducer depending on how thick the paint is.... most clears are 4 to 1(meaning 4 clear and 1 hardener) tape first all the edges and then on top put the paper... will you be using newspaper????
    Scottish Scotsman's Avatar
    on the road to recovery
    what size compressor do you have?
    Norcross
    using a 60 gal compressor. i forgot the cfm, but i'll look that up tomorow. Yes i will be using news paper
    Aug 2009
    Quote Originally Posted by Crazydelsol View Post
    Lol at this post
    LAWRENCEVILLE
    Rule number one! Take your time even a cheap garage paint job can look decent but 75% of a great paint job is in the prep work this is also the part that takes the most time. If you dont have a clue how to work a gun and lay paint talk to someone who does. And about mixing them paint some paint brands are diffrent ratios pick up a few mixing cups to help you with this part. Also I like to use all the same brand if im laying down a ppg base coat I want to use there brand of clear.Yes some guys mix and match But some are not compatable together. I could go on and on But do your research and have a Idea of what your doing before you even start the prep work and way before touching a paint gun.
    Hella stock member!
    Feb 2010
    A-town
    Quote Originally Posted by Austin? View Post
    Lol at this post
    Laugh at his tips but they sure get the job done!
    You don't always need a paint booth for a 99% perfect paint job. Mine was painted b4 the shop could afford the paint booth so if you need some help hit crazydelsol up.
    Before
    After
    LAWRENCEVILLE
    Also What color are you planing on painting? If its a silver or something with a lot of pearl or flake you might not want to start with a color thats difficult to spray for your first paint job.
    Hella stock member!
    Norcross
    Going for a blueish-green color. Yea I'm not doing this alone, i will be getting advice from a painter, but i will be doing 100% of the work. Its a learning experience for me, so just trying to learn a few tips that may help me
    Jan 2011
    Lol at this post
    i dont see nothing to "lol" at
    Quote Originally Posted by RsonGt3's View Post
    Thanx n yea the integra came out clean
    Jan 2011
    Quote Originally Posted by j0nbunklah0m View Post
    Gl man hopefully everything comes out good
    Winder,Ga
    Quick Tip! Dont rattle can..
    It's not the speed that kill's its the sudden stop at the end.
    Norcross
    thanks man!
    Quote Originally Posted by masanomi3 View Post
    lol k thanks
    Certified Gearhead spank's Avatar
    Feb 2010
    Are you going to use single stage paint or base coat and clear?
    Norcross
    going for base coat and clear
    IA Member Bugginferio's Avatar
    Feb 2012
    NYC/Gwinnett
    bumpp i would like to do the same... goodluck
    Norcross
    i got it painted. it turned out pretty good, some orange peel and a few runs, but all in all not bad for a first timer
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Hell yeah, Laos!
    Show them what's up
    IA Member PhatBoi1210's Avatar
    Dec 2010
    Lilburn, Ga
    Post up some pics
    I need a smaller sig pic
    So did you paint outside or in a garage or something becasue im painting my car soon for the first time n need all the advice i can get too lol
