I was thinking of using anti-lag to build boost for roll races and I wanted to know could it be done?? I rather use anti lag to save my pads. any feedback is welcome.
2006 Evo IX - Bolt ons
Yes, it can be used. You are simply changing the timing to make the ignition happen at the end of the stroke - in the exhaust rather than in the cylinder chamber. It is hard on the turbo though.
Ask yourself this question: Which is cheaper, brake pads or a new turbo?
good point, I still have to say my pads at $127 for a pair and a turbo rebuild is 400. But taking my turbo off is a piaOriginally Posted by David88vert
Why not use both? BB for the initial jump & anti-lag between shifts.
www.toyotaofroswell.com
Current: '04 S2000
yea I was going to do that from the start, but just wanted to see comments about this methodOriginally Posted by ct9a gsr
Get used to buying new turbos if you're running antilag. I've heard Garrett turbos in particular cannot stand any kind of anti-lag.
The way that it works is that extra fuel is sent into the cylinders not firing and then it is blown into the exhaust manifold where it ignites and creates more exhaust gas to keep the turbo spooling. It will be loud and obnoxious but you'll have no lag.
02 WRX Sport Wagon
I am running an apexi turbo right now. I wouldnt run anti lag all the time, nothing is made to last forever when it comes to performance.Originally Posted by GTScoob
heh... anti-lag puts a good 'bit of stress on MANY parts of your drivetrain... definitely not the healthiest thing around... I still refuse to setup anti-lag between shifts on my new setup like I had on my gt35r... too scurred. =/
Current: '04 S2000
This is why I am doing research on it, b/c I have never used it. Im still thinking of setting it up on my stock motor, b/c its going to get built next fall. But with my small quick spooling turbo I may not need it in between shifts and may just use it to launch
LOL poor 35r =(Originally Posted by ct9a gsr
Charles I thought that crazy amount of boost you were running on the gt35r, is what led to the death of that turbo
lol HAHHA no the death of the gt35r was him being dumb and not listing to meOriginally Posted by TIGERJC
long story short bolts got lose= turbo houseing to full off= chipping the hell out of the fins of the gt35r= bybygt35r
you dont need anti lag in between shifts. They dont use it in drag racing so I dont see why you would need it street racing.
Garrett turbos hold up pretty well, all these companies come out with new things that are supposed to be better than the garretts but no one has come out with anything thus far. All the big guys in sfwd are running garrett turbochargers. Anti lag is pretty hard on the turbocharger but who is holding it for long periods of time? Its not like a 2 step that you have to be on to build boost, with antilag its just that.
Turbine housing bolts backed out causing the inner wall of the housing itself to scrape and chip the turbine blades. Either anti-lag conditions or lack of torque on the bolts or both caused 'em to back out. Running "extreme" amounts of boost didn't hurt it. Hell, I ran 30psi upto 34psi on the stocker and it still works perfect with no shaft play. =DOriginally Posted by TIGERJC
Current: '04 S2000
Actually regarding turbos that are built to withstand anti-lag yes there are better options than Garrett turbos. The IHI line of turbos for Subarus stand up to a lot of anti-lag abuse and are what is used on the rally cars, certain Mitsubishi turbos are also built to hold up better under anti-lag. I'm not sure exactly what is different but they just happen to hold up better when using anti-lag.Originally Posted by josh green
02 WRX Sport Wagon
Well I have a IHI-RHC6, is that a IHI turboOriginally Posted by GTScoob
The IHI line of Turbos that is meant to handle anti-lag isnt just any old IHI turbo, you can get the anti lag ready turbos from prodrive, and true anti lag is more than retarding the timing etc. That is if you are talking about rally style anti lag.
Matt
Originally Posted by Slowwrx
I remember reading something on an Australian subaru forum years ago where all the guys down there were talking about how their VF22s held up much longer than the Garrett turbos and Mitsu turbos they had tried.Originally Posted by Big Baller
Anyways, to answer your first post, I dont think anti-lag would help you build boost from a roll, its main purpose is to keep the turbo spooled when you are off the throttle.
02 WRX Sport Wagon
Anti-lag IS used in drag racing, and can be used with a 2step. It is just setup differently than rally racing.
Most aftermarket ECUs that have anti-lag, like Motec and AEM, use a retarding of the timing to go to a rich condition and introduce unburnt fuel into the exhaust housing of the turbo. You have to go pretty far past TDC to do this (usually I start around 40 degrees). This is the way they do anti-lag for drag racing.
Rally sometimes uses a different way of getting gas into the exhaust manifold - but the effect is basically the same. Some systems have separate injectors that shoot fuel directly into the turbo manifold.
Anytime you have fuel being burnt inside the turbo, that build heat and puts stress on parts.
you dont have to pull out 40 degrees on a honda, I know a lot of guys used MSD or some ignition box to use as antilag. Digital 6 you can retard up to 10 degrees for "nitrous" but you can use it however you want. Thats enough to build a good bit more than just a 2 step.
