Results 1 to 22 of 22
Thread: LS/Vtech
    lawrenceville and Cartersville
    Default LS/Vtech
    I have a question about my LS motor that has CTR pistons in it with a high compression of arouned 11.7 i read somewhere that it is a good set up for LS vtech but also heard it would make my motor blow real easy someone let me know whats up.
    Belview Insane Asylum
    Quote Originally Posted by 94LSEG
    Cordless phones and engines don't mix. They don't even run on the same voltage. That would involve integrating a power inverter into your harness for the phone, and where would you tie it into? Your ignition? Can you make it control timing? Even if you could get it to work it wouldn't add any horsepower.
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    So are you saying he has to wire it so that V-Tech kicks in at 900Mghz
    www.ATLphoto.net Myspace
    Quote Originally Posted by GA_Teg
    No, it has to kick in at 1.21 gigawatts!
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    I thought it was Jiggawatts
    Whatever.
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    Whatever.
    Don't make me break out the Flux Capacitor on your ass
    Where did that plutonium (sp) come from again?
    Senior Member 99SI's Avatar
    Jackson
    noob bashing, lol. Just in case the author of this initial post wasn't aware VTEC is the name of the variable valve timing that makes the LSVTEC so enchanting. VTECH is a phone. But to answer your question, LS rods are inherently weaker than VTEC rods which could lead to your only problem. Keep the rev limit around 8,000 and your compression ratio shouldn't come into play that much as long as you're running 93octane everytime all the time. Do not get cheap on the gas with a high cr. Otherwise the compression shouldn't make much of a difference as long as you did the rest of the conversion right, just don't try to spin it too high.
    DC5-R
    Gwinett
    he's right, but all in all if you want to make it easier on yourself but not cheap just buy the ls/vtec conversion kit. CTR pistons are great for ls/vtec due to higher compression than using stock internals i.e. ls.
    Where is VtecKidd when you need him? He knows more about N/A crap than I do.
    the old man NAIZBST's Avatar
    he is basking on the beach in florida will palma and fistina
    Quote Originally Posted by integ97
    I am going to ask **female's name withheld** if he yells "Skunk 2" during sex.
    bitches!
    LS block with what head? with a GSR head its like 13.0:1 compression, and it will blow, the pistons will not clear the deck height , they stick out of the hole. IE the pistons will slam into the deck of the head, and overtime, pound the rod bearings out of the rods, thus spitting arod out your block.
    CTR pistons belong in ONE engine, and thats the CTR motor. IMO
    TADA! The N/A king makes an apearance!
    or yells take my pro 3's in and like it :idb:
    DC5-R
    Gwinett
    Quote Originally Posted by krucial7integra
    VtecKidd is the N/A king. Errbody bes recogniZe!
    DC5-R
    Gwinett
    yeh he mine as well go join tsuchiya and keioffice for a living, maybe show them a thing or two
    What do those two have to do with N/A tuning? :confused:
    he is comparing them as mike is the n/a king and they are the drift king
    Do your Kei Office coilovers allow you to drift your DC?
