Nobody said this was a Honda-only discussion so I thought I'd mention a low-boost SOHC making some powerOriginally Posted by LSTurboHatch
>> 94 Dodge Stealth - Slow
>> 94 Dodge Stealth
sohc zc vtecs???? pm me a priceOriginally Posted by B18c1Turboed
i know people personally that have made 400+ on stock engines with vitara pistons and eagle rods.Originally Posted by Mr. KiDD
once again. its all in the tune.
o and btw that 568whp car runs 10.06 with traps in the 140's... i dont think your going to find many gsr's with 250 horse go that fast.
preaching to the choir man, i run a built bottom D with vitaras and scat rods. stock head with arp studs and HGOriginally Posted by Gr33n_EK9
Hell yea.. x2 Been there done it 3x and now im on my 4th but this one is going to be all out. Everyone I have blown up I loved everysecond of it. The other motors were all stock with stock internals.Originally Posted by bernard
thats the way to go. i would be running vitaras if i didnt get such a good deal on these wisecos.Originally Posted by blue_5g_zc
Vitara pistons and eagle rods are now stock Honda parts?Originally Posted by LSTurboHatch
That doesn't sound very stock to me.
>> 94 Dodge Stealth
must be running that 10.06 with slicks because with the power he gained out of nowhere is a guaranteed spin with street tires.
319whp bone stock SOHC only bolt ons, cam and a larger turbo no head work, motor never opened at 190,000 miles....Nobody said this was an all honda thread.
http://i.pbase.com/g6/43/638743/2/75622719.fQCNivVp.jpg
My car is factory....
Every single performance part and or modification it has was made in a factory somewhere.
Ive only seen so many d series that last that are stock... i call bs ^^^^
It all depends on the tune, and how hard you run your car bro. If you baby your car boosted on stock internals, it will last awhile. I ran the bottle for a yr. then boost for a yr till my rings went. Like i said, it depends on the driver and the tuner.
where did you get your zc parts... and are they dohc?
I♥my ruckus
~Lagg Squad~
<turbo negros>
I put the sexy in dyslexia.
R.I.P steven bond....
they're sohc zcOriginally Posted by callmetree19
D-series is just a waste of money, b-series power can be obtained with less moneyD< B
GECKO SQUAD MEMBER
MSS RACING REPRESENTA.....
the saga continues....
haha....Originally Posted by JDMjoe86
gsr swap=2500=163whp.
boosted d setup=2500=300horse.
who wants to do the math....
i own both a b and a d. gsr's cost around 1200 for just the engine. i can build a d-series bottom end for 1000. i would much rather blow up a d-series and replace it than blow up a b-series.
x2Originally Posted by LiLJames93
not to thread jack but would a T3/T4 turbo b a good SOHC turbo? or will it not spoll up enough when the redline is about 6k?
DOHC or SOHC doesn't matter. And being a T3/T4 doesn't matter. What matters is the volume of air and exhaust pulses from the head and the turbo's exhaust turbine and exhaust housing.Originally Posted by 1NonlyAccord
Asking if a T3/T4 turbo will work on a SOHC engine is like asking if a Goodyear tire will fit on a Lexus. Maybe? It depends on what kind of Lexus you have and what the tire's width and sidewall is. The question is really too vague to give any meaningful or useful answer.
But it's very possible to match a smaller SOHC engine (since you are probably talking about a Honda) to the propper T3/T4 to make it both responsive on lower RPMs as well as produce good top-end. Things like head work, the engine's compression, and different cam specs will change what specific turbo or variation of a turbo will best suit the engine and your needs from the car.
You can now buy ball-bearing T3/T4 turbos instead of journal bearing which will shift the turbo's efficiency range to be more effective with low-end power. On the flip side they not only cost a lot more, but if the center section is damaged you'll probably be replacing the turbo or spending a lot of money getting it repaired. Journal bearing turbos are much cheaper/easier to rebuild. It's a trade-off. If you have the extra money then by all means go with a ball-bearing. I would also look into the Garrett ball-bearing GT-series turbos.
>> 94 Dodge Stealth
J series rules ive got a boosted j 30a1
makes me think about keeping my D series in my Hatch or at least switch from the D15 to a D16z6 and do some F/I work on it...
Please refer to Bisi Ezerioha. F22A SOHC non-VTEC making 500 N/A HP. that is real HPOriginally Posted by w3bcod3r
x2Originally Posted by hotshot
true story.
Im building a 500+whp stock sleeves d series. I have maybe 3k in my whole setup and it will be a low 10 if not high 9 second car when im done. Let me introduce you guys to some REAL D SERIES setups!
Here's a full weight full interrior 4 door eg that has 3 mods to the motor it's self that runs 11.2's and has less then 600 dollars in his motor. He dynoed 405whp and 314trq with a ebay t3/t4. Still running 3 years later!!
http://www.honda-tech.com/zerothread?id=1719843&page=1
http://www.honda-tech.com/zerothread?id=1748160
Here's a hatch thats nearly stock with less then 4000 in the whole car that runs consitent 10.3's, not to mention it's been doing this for 3 years. Hows 471whp/356tq @ 29psi on 101 octane reving to 9100 sound? and this is not the highest power this car has made..not to mention he's also running a ebay t3 t4.
http://www.honda-tech.com/zerothread?id=2295855
Here's a Friend of mines 500whp d16 hatch i talk to often on H-T that is DD with a/c and p/s still. Once again less then 2500 in his motor as well.
503whp and 345trq
http://www.honda-tech.com/zerothread?id=2337047
Here another full weight 4 door with a nearly stock boosted d16 thats runs 11.2's
http://www.honda-tech.com/zerothread?id=2392446
Here's a 605whp with 403trq d series with less then 3k in the motor...
http://www.honda-tech.com/zerothread?id=2371560
ALL THOSE MOTORS HAVE STOCK SLEEVES AS WELL!
D-series motor are awesome to play with. MOST UNDER ESTIMATE THEM! No one around here takes time to do things right now days. Show me a 500-550whp b series that runs around 10 flat or high 9's.
BULL **** my girl's brother made 254whp and 217trq on a stock d16y8 with a ebay kit and drove the **** out of it for 8 months and ran it low on oil and spun a bearing. Now he put in in 120 dollar vitara pistons FJT Custom rods and dynoed 412whp 326trq at 28lbsOriginally Posted by LiLJames93
Rota92's car is sick runs 9.1's I bought his old Head package from that setup.. with his RLZ Head he made 585whp. And to the fool who said not a bad way to spend 10 grand he actually has right at 5 in motor and stuff.Originally Posted by B18c1Turboed
Depending on how much you spend it is possible to get 600-700 hp out of a fully built and tunned SOHC honda, but that cost mucho denaro(sp?)
honestly i could make that kinda power with about 800 more in my setup for sleeves but i dont want that much. My EF will weighs around 1300-1500 without the motor so 500-550whp is more then enough. I actually know some with a built and sleeved d16 block for 1500 shipped i thought about getting for a back up.Originally Posted by qwick
Yea I no what ya mean I just wanted to say that even thoes tiny motors could make big HP.Originally Posted by -S Double C-
man if only i had my civic my 4 do' damn would i buy that motor. i would be shittin on some hoes lolOriginally Posted by -S Double C-
AV6 FTW!!
he is so fucking rightOriginally Posted by LSTurboHatch
AV6 FTW!!
He did not run 9.1 he ran high more like 9.7s wich is still impressive,But nowhere near 9.1 theres only a few cars that have ran that and he wasnt one of them...
Just to clairfy it was a 9.85 @ 145 - SOHC
And the car also has wheelie bars and is a Hot Rod car, that means pure drag car!
hell ya you can get some power outta the SOHC...i roll a turbod stock SOHC vtec and make 230-240whp
My personal opinion, yeah you can get some horses out of a sohc. But you need to seriously build it before you boost it, and even then you run a high risk of blowing it. I would go with a b series, any b series. Yeah, it's a typical swap, but much more dependable, you can boost it stock and it'll last you. And if you build it first, and THEN turbo it, we are talking about some serious horsepower, so it all depends on your purpose, just a fun car, or maybe for racing sometimes, but either way, if you want to boost it,I would just do a b series swap
and who said a stock d wont last if boosted stock everbody and there granny has a b-swap including me well i had one but got rid of it now im a sigle cam guy andOriginally Posted by jakerd4892
whoever dont like it thats my personal opinion
Soon!!
