Results 1 to 13 of 13
Thread: Ground Control Coilovers
    Default Ground Control Coilovers
    Can you use Ground Control Coilovers with Skunk2 Sport Shocks?
    Krispy Kreme
    if it's the full coil setup, why? i mean why waste em... all i might change are the springs, but skunk can custom make..
    NIKOND80
    PG+K
    No reason you can't, it's an OEM replacement just like any other shock...
    http://www.skunk2.com/Suspension/ind...dId=sportshock
    Just slide the ground control sleeve & perch on then the Eibach spring.
    Krispy Kreme
    why not rock the matching skunk2's... or get a fullcoil setup... but i assume you already got GC's and want to get these shocks...
    NIKOND80
    PG+K
    Snellville/Statesboro
    Just search for ground control's on ebay, and it should tell you which strut they will work with in the ad.
    For instance: http://cgi.ebay.com/ebaymotors/GROUN...QQcmdZViewItem
    UPROOT Photography FTW
    Quote Originally Posted by burke420
    spring rate....
    Newbie Photodude RBS's Avatar
    All Over U S A
    buy the full coilover GC/Koni setup with custom springrates to whatever you like, makes things simple . .
    Hwy 315
    ^worrrrrrd
    top notch setup used by many a HPDE driver
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Senior Member steedracer's Avatar
    winder
    gc ride smooth got em on my 96 civic.
    Got tein springs on my car now. I am going to get buddy club coilover in a few months.
    let this die now
    ATL, GA
    I hate ground control coilovers. Those kind of shocks just are not made to work like that.
    Quote Originally Posted by chituntang
    huh?
    ATL, GA
    Shock from coilover and from normal shocks are design differently.
    That's why the real coilover needs to rebuild over times because the abuse they actually get.
    The normal shock has a longer life, but there is a travel distance they were designed to work at. So that's why a lot of people would not recommend stock shocks with lowering springs. I know that he is going with aftermarket units, but that is still not a real coilover. If you really want the adjust ability, getting tein basic will be a way better choice.
    The biggest thing is how often you are going to adjust it. I have a set of KYB AGX and I have only adjust it once. We are talking about turning the knob. It is not like he is going to take off his wheels every week/month and put it 1' higher...
