Results 1 to 11 of 11
Thread: Clutch pedal sticking to floor.
    '92 EG Hatch Sunkenkarma's Avatar
    Flowery Branch , Ga
    Default Clutch pedal sticking to floor.
    Alright, so tonight I decided to replace my clutch slave cylinder, because the old one was leaking, we installed the new one, bled the line, and all that, but now the clutch pedal is on the floor, I can pull it back to me, but it just goes back down when I let go of it, its almost like the fork isnt grabbing the slave cylinder, we had luck a few times, but it kept loosing pressure. To bleed it, we took a plastic hose, to the bleed screw, pumped the clutch, depressed it and re tightned the screw, I dont really know what could have happened wrong. Before this the clutch worked fine, went into gear, master cylinder is working good from what I can tell.
    If anyone can help out, that would be amazing. its a 92 hatch, d15b swap, P20 Tranny.
    [/URL]
    My best bet would be the master cylinder is bad or you got a bad slave...
    no joke, I went through 2 master, and 3 slave cylinders in 1 night because they were all faulty parts, even though I was buying new. I'd try a different master, then slave. Did you check to make sure the actual pedal looks right? Spring is good, adjustment rod isn't on fire? etc.
    Senior Member iam99x's Avatar
    Athens
    If the fluid doesnt come out in a steady stream, there is still air in the system. Make sure that is happening.
    Also, be sure you havent ran your reservoir low from bleeding the lines.
    Allen @ MPA
    Still air.
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    Sounds like you still have air in your line. Try bleding it until you get a steady stream of fluid coming out. Or maybe its a faulty new part.
    Flowery Branch , Ga
    It was the clutch master cylinder, pick up a new one, bled the line and it works better than before, Thanks guys.
    [/URL]
    when you have your clutch pedal down and hold it down, then bleed it from the slave and close up the screw at the slave and let off the clutch pedal. Do this a couple of time until you have a stream fluid and make sure you master cylinder is not low on fluid while you doing this.
    McDonough
    Quote Originally Posted by jdmalltheway View Post
    You made mistake where you pumped your clutch, you still have air in the system. You have to bleed it just like you bleeding brakes.
    You are just a couple days derp'd. He figured out the problem.
    Bitches love bacon.
    Jan 2012
    x2 on the bad slave and master. my car was down for 2 days because new parts were faulty.
