Thread: Tire size question
    Norcross
    Default Tire size question
    How can i find out which size tire i can put on a rim? currently on the rim is 185/65/14, i want to go with 205/50/14, but not sure if it will fit sorry for the noob question. but thx in advance for help
    Macon
    Quote Originally Posted by j0nbunklah0m View Post
    I usually use this.
    Stock Tire - 185/65R14 Tire 1 - 205/50R14
    Section Width: 7.28 in 185 mm
    Section Width: 8.07 in 205 mm
    Rim Diameter: 14 in 355.6 mm Rim Diameter: 14 in 355.6 mm
    Rim Width Range: 5 - 6.5 in Rim Width Range: 5.5 - 7.5 in
    Overall Diameter: 23.46 in 595.88 mm Overall Diameter: 22.07 in 560.57 mm
    Sidewall Height: 4.73 in 120.14 mm Sidewall Height: 4.03 in 102.36 mm
    Radius: 11.73 in 297.94 mm Radius: 11.03 in 280.16 mm
    Circumference: 73.70 in 1871.9 mm Circumference: 69.33 in 1760.9 mm
    Revs per Mile: 886.6 Revs per Mile: 942.4
    Actual Speed: 60 mph 100 km/h Speedometer1: 63.7 mph 106. km/h
    Speedometer Difference: - Speedometer Difference: 6.293% too fast
    Diameter Difference: - Diameter Difference: 5.93%
    There's your specs. The one you are thinking about replacing it with is way too small.
    Your best bet is a 205/60/14. You could get away with a 205/55/14 if you were low enough.
