Results 1 to 6 of 6
Thread: GSR&B16
    ATL ROAD HOG fabulous's Avatar
    WITH UR GIRL
    Default GSR&B16
    i'm trying a combination of b18c head with a b16 block, just wondering if anyone tried this before? how does it run NA and how about with boost....???
    I LUV VTEC DO U!
    In a mansion
    Its not a bad setup, i would have flipped the other way, it gives you a little more power if everything is stock. For boost it should be fine if you change the pistons and rods. Just my 2 cents hope it helps.
    Senior Member BlueHatch's Avatar
    Green Acres
    ^^^listen to him i boosted my b16 and blew a ring. look hard enough and you will find upwards 25 people at least who have done the same thing. at least go with gsr pistons. i actually have an extra set if you want them. pm me
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    B16 Pistons are not good for boost.
    Certified Gearhead Supacharge's Avatar
    Charlotte
    just a question .... but arent b16 and gsr heads pretty much the same as far as flow goes??? for example, ls/vtec typically uses b16 head, right? why not a gsr head then? any input on that?
    00 Civic Si turbo
    ls/vtec 592 whp @ 22 psi
    **RLZ ENGINEering**
    Quote Originally Posted by sleepys4
    This statement isnt exactly true. By changing a from the b16 head to a gsr head on the b16 you are raising the compression, the combustion chambers are smaller on the gsr head. As far as flow goes, stock for stock they are basically the same. It would be better for boost to put put the b16 head on the gsr motor, but really not worth it. People use either head for an ls/vtec. There is no one over the other, its basically what you can get, or your preference. A lot of people get the b16 heads b/c they are a little easier to get than a gsr and are cheaper.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
