Results 1 to 3 of 3
Thread: GSR Block with Type R Head: 60-1 Turbo - E85 Dyno Tune
    Moderator Spent's Avatar
    Mar 2010
    Greenville, SC
    Default GSR Block with Type R Head: 60-1 Turbo - E85 Dyno Tune
    This setup belongs to Zach. Sorry guys, no pics. We tuned this one last night.
    Type R Head with GSR Cams
    Stock GSR bottom end
    Garrett Ball bearing 60-1 (t3/t4)
    Tial 38mm Wastegate
    Tial 38mm BOV
    Back door intercooler
    880 Precision Injectors
    Aeromotive 340 Fuel Pump
    Adjustable FPR
    ARP head studs
    68mm Throttle Body
    Tuned on Crome Gold with E85
    The chart is at 10.8psi. For the record, it made 350whp between 7.9 & 8.1psi when tuning the wastegate during the earlier runs.
    ECU chipping services & one stop tuning for: Crome Gold, S300, K-Pro, Flashpro, AEM EMS, AEM F/IC, Haltech, Motec, PowerFC L & D-Jetro, Nistune, Utec, Unichip, Cobb AccessPORT, SCT, DiabloSport, HP Tuners, Tweecer, Big Stuff, FAST, Map-ECU,TurboEdit, C.A.T.S, Megasquirt, Microtech, DSM Link, CPE Standback, SAFC, VAFC, NEO
    Hubert Murias
    [email protected]
    864-699-9436
    GWINNETT IS GREAT!
    thats sick!
    only @ psi?
    Mar 2010
    Greenville, SC
    Right. It really doesn't build 11psi till right at the very end (manual boost controller). It's pretty wild considering it took 5 more psi on a GT35R to make the same power on my K20z1, then again I was running pump gas and this setup had the head machined and it's already of higher compression. Regardless, numbers are numbers. From a tuners perspective, the quality of the chart itself speaks louder than numbers in most cases and give you a better picture of what exactly is going on (spark knock, blowout, lack of timing, etc........).
    The following chart is with the smoothing factor turned all the way down (a.k.a maximum resolution).
    Hubert Murias
    [email protected]
    864-699-9436
