Results 1 to 22 of 22
Thread: projector head lights
    paint booth
    Default projector head lights
    can you put a H.I.D kit in a set of projector halo head lights?
    ಠ_ಠ Kamikaze's Avatar
    Fulton Co.
    Yes.
    I don't see why not.
    At Home
    yes I have and they turn out great
    Germany
    what kind of projectors? halogen projectors? yeah you can but light output's gonna suck!
    Society-ZERO-Member #7
    VTEC yo!!!!
    Quote Originally Posted by 97WhYt_TeG
    i put a set of hids in audi a4 halogen projectors and they worked great.
    deaths due to street racing in the world in 2004:141
    deaths due to falling coconuts in the world in 2004:151
    deaths due to children falling into five gallon buckets in 2004:487
    make sure you get the right bulb
    At Home
    X2
    Gainesville
    you have a set of halo projector headlights like the ones you can get off of ebay.. then NO.... you will melt them.. regardless if you got the from ebay or not. the plastic they are made of cannot withstand the heat produced from a H.I.D. kit... i also know from a personal experience, well my friends car anyways.. i told him it would happen he didn't listen and he did it anyways and it melted them.. but if your car came stock with them then yes they should be able to hold the heat and not fuck up...
    paint booth
    my factory head lights are plastic too.
    Germany
    i mean like street speed said....plastic might melt i'm not too sure about that....never had plastic housing. but for the projectors.......i put s2000 hid's in my dc2 and the stock halogen projectors sucked....light output wise. there was alot of "hot spots" and dark spots. So i got merecedes c class hid projectors and retroed them in there. after that the light output was nice and even
    Gainesville
    lol i ment to say certain types of plastic will melt... most cars come with stock plastic housing.. but they can handle the heat... and alot of after market head lights can not
    paint booth
    every hid company i have checked on say hids dont put off as much heat as regular bulbs.
    thats what I was thinking
    i been noobified... O.o happyhooder's Avatar
    north east of Atlanta...
    start up the heat is higher than halogens b/c the hid bulbs need to warm up... reason why you see a color shift when you turn them on... but once the light is at to the temp it's unning on less volts and less heat than oem... so there is a chance of melting...
    is this aftermarket projectors or oem?
    reason why i ask is that if it's aftermarket projectors if i were you swap the projector housing with an oem HID projector like the s2000/audi tt, etc... and use a d2s bulb with a d2s bulb wire harness to your aftermarket ballast... that way you get an OEM projector look, but also the brightness on the road... if you do that don't go over the 4300k oem bulbs... or you will lose the lumans aka brightness...
    it would be ideal if you let us know what you are using... and for what car...
    paint booth
    i have a 96 civic, as far as know they dont come with oem projectors. how do i change the housing?
    Gainesville
    buy the whole headlight
    paint booth
    if you mean buy the whole light for my car then i already have a set. i thought happyhooder ment take the housing out of something else and put in mine.
    Gainesville
    no you can try using them but it will prolly melt them.. but what you could try doing is getting the inside of a headlight from a car taht come stock with projectors then retro fitting them then install
    paint booth
    what would be the best car to get them from.
    Gainesville
    most likely a bimmer i would think
    paint booth
    ok i got my H.I.D kit and they work and look great, no melting problem.
