Results 1 to 13 of 13
Thread: Please freaking help me
    ZERO sir2hb's Avatar
    L.B.C (little bitty calhoun)
    Default Please freaking help me
    Ok have you ever wanted to stick a rag in the tank andt light it.
    I am a pretty good with a honda but iam f*cking stumped.
    Ok here the is what I have I got a b20 with a gsr tranny, ls intake, edlebrock 65mm tb(brand new), gsr harness for future vtecing, LS ecu, Honda n1 crank pulley, AEM alt. pulley,
    Ok here is the problem as iam actcelluarating the motor bogs down like it is not getting any fuel, the tach is jumping all over the place. When i barely give it gas it is ok, but if I lay on it it bogs down tach jumps everywhere. No codes I cant figure it freaking out and it is pissing me off FUCK.
    Can anyone help me or know of a good honda shop.
    I never won any spelling bees
    Horsepower looks good on paper, Torque wins races.
    Jan 2005
    Columbus, Ga
    i dun kno if this will help, but mine bogged alot too, i have a b16a2.....i changed the pcv valve and it doesn't bog as much now, only when i try to floor it, i was suggested to change my spark plugs, also fuel injectors (? maybe) and distributor...might wanna check those out, but try the pcv valve first...hope it was a lil help
    edit*** it only bogs in first gear for me now
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    RISKY RISKYB's Avatar
    athens
    check all your grounds, thats what happened when one of my grounds went bad, or maybe a clogged cat mights cause it to bog down
    Quote Originally Posted by black_civic_si
    Yea i changed the plugs and i have ngk plug wires new iam about to put a new cap and rotor on it here in about 10 mins
    Jan 2005
    Columbus, Ga
    alright, go to autozone or any other place, get a new pcv valve if your car has one...i think it should, mine was clogged up bad which caused alot of the bogging
    See since the tach jumps around crazy like iam thinking like RISKYB said it might be a bad ground or a dissy problem
    O and i replaced the pcv as soon as i got the motor i justed rembered
    where are all the grounds i know of 3 the tranny, vavle cover, and thermostate cover, any where else
    I have a full kteller exhaust and a brand new magnaflow cat
    My CRX is stock I PROMISE SLEEK-CRX-SI's Avatar
    Norcross
    You may want to change your ECU it may have been dammaged durrinug the swap you may also want to check your fuel filter and fuel pump. I had that prob once and it happened to be my fuel pump it was going bad and it could not keep up with my fuel consumption when I floored it and my RPM guage would go crazy b/c the ECU was confused about the air intake vs fuel ratio. Hope that helps!
    Senior Member 99SI's Avatar
    Jackson
    Do the rag in the gas tank and light it thing. I think that will solve all of your problems. Just make sure you've got about a half of a tank, that way there will be plenty of fumes which are what really do the igniting.
    probably misfiring... my impreza used to do that (when I had it) and it was misfiring... just check plugs, wires, cap, and might want to do a compresion test...
    Hwy 315
    blow it up, that'd be sweet
    [/URL]
    Jesus Christ is my Savior
    Well u guys who want me to blow it up are out of luck it was a loose ground
    Thanks guys for the help and trying to get me to blow my car up
    i know you fixed it but i'd still run stock plugs and honda wires...
