Thread: no more p28 pistons
    Default no more p28 pistons
    I want to do away with my tired p28 pistons and exchange them for a higher compression piston. Can anyone direct me to a piston that requires no modification to the block and isn't going to have a valve clearance issue inside of a d16z6. I would prefer an easy direct replacement.
    Ur moms house
    why wont you try too use some jdm zc shoc non VTEC pistons?? (why you ask) because you can raise the compression up that means more power
    Im looking to upgrade my rods and pistons, but i dont want to end up in the 12:1 range. Im looking for something a little more milder and reliable like 11:1. Any suggestions for a rod and piston combo that doesnt require any block work and that doesnt break the bank?
    Ur moms house
    just try some of the stock zc dohc rods they might work out good for you . whats wrong with the piston you dont like them??
    even with 11:1 range C/r your going to need to be tuned, may as well step it up to 12:1 or so and its still reliable with good tune and gas.
    In the Fucking A
    12 to 1 that shits weak, real men get started at 14 to 1
    I fucked İhris's mom
    tru, bump that shit to 21:1 and run diesel
