Thread: FADING CARBON FIBER hood
    tink tink btldzc's Avatar
    COG
    Default FADING CARBON FIBER hood
    is there anyway that you can fix the blemishes on the hood...i think its wax it looks oxidized....can you wet sand w/ 2000 then buff and polish?
    IN LOVING MEMORY OF GAI
    SEE YOU WHEN I GET THERE BOIE!
    3/8/75 TO 4/18/05
    Senior Member 00CIVICSI's Avatar
    Augusta,ga
    check on honda-tech i just seen a thread about a guy that restore his.
    down the yellow brick road
    if u wet sand it, then you have to get a rubbing compound that will cover the marks left by the sandpaper. Then polish and wax.
    COG
    were on honda-tech?
    3/8/75 TO 4/18/05
    My CRX is stock I PROMISE SLEEK-CRX-SI's Avatar
    Norcross
    yeah sure you can do that but like the others said you will need a buffer some rubbing compound and some polish. It's very simple but if you do not know how to use a buffer I would let someone else do it. It is very easy to catch a corner and take off the clear coat and/or paint on fenders on the edges. Be careful around plastic also.
    After that it should come out almost like the day you took it out the plastic! Hope I've helped!!
    Certified Gearhead ILLSMOKEu's Avatar
    Sandy Spring
    Honda-Tech Under "Welding/Fabrication"
