Results 1 to 13 of 13
Thread: knock sensor
    WHEREMYBITCHES dowhatido's Avatar
    lost
    Default knock sensor
    i have a b18c1, my check engine light is one, doesnt come on right away, but after crusing for a minute it pops on i changed the o2 sensor, but some1 told me that the knock sensor itself may be bad i dont know where it is located, can any1 describe where this is located- i figure this is side mounted but i have no clue where or what i'm looking for??????????????????????
    i dont think the engine is bad runs good while it's not on but when it turns on and retards my ecu runs like shit, doenst sound like it's knowcking though.
    bong rips prefered!
    RIP 94 ej1/b18c1
    welcome rebirth of 93 eg/b18c1
    have you actually jumped the svc connector to see what code your getting? if you did and it's knock sensor, why change o2?
    lost
    no i have not ran diagnostics on it, (i'm broke right now)(xmas) that way it was cuttin on i just gave the o2 a shot, i replaced it with a used o2 sensor as well but it wasnt trippin ecu in my buddys car????, thats why i figured now i'll change the knock sensor, i just dont know where or what this sensor looks like
    bong rips prefered!
    RIP 94 ej1/b18c1
    jumping the svc connector won't cost you anything and will tell you what the issue instead of you spending time and $$ chasing your tail.
    lost
    give me more detail, not 100% sure on what you are talking about
    bong rips prefered!
    RIP 94 ej1/b18c1
    if you go on the passenger side, where your ecu is located, there is a 2 pin blue connector up close to the bottom side of the glove box, stick a paper clip in it and the check engine light will flash, count the flashes see what ya got...
    lost
    4 slow 3 fast??????
    bong rips prefered!
    RIP 94 ej1/b18c1
    check out honda tech
    lost
    honda tech .com?????
    bong rips prefered!
    RIP 94 ej1/b18c1
    honda-tech.com
    lost
    ya i'm not really good with that web site, i'll look it up see if i can figure it out thanx a lot man
    bong rips prefered!
    RIP 94 ej1/b18c1
    lost
    ok i got it now, i throughing code 23-knock sensor, and 43-fuel supply system
    ???? i dout my engine is knocking, so where is this knowck sensor at??????
    bong rips prefered!
    RIP 94 ej1/b18c1
    4 slow and 3 fast w/o much of a pause between flashes is 43.
    are you also getting 2 slow and 3 fast after that?
    knock sensor is usually on the back side near the top of the block/below the head.
