Results 1 to 13 of 13
Thread: lowering springs needing camber kits?
    "CHAMP"
    Default lowering springs needing camber kits?
    Does any one know if after you installed your lowering springs to get camber kits?
    just got tein s tech installed. now i need to know if i need the rear camber kit?
    i think (not positive) the more u lower a car the more negative camber u give it. because u've just changed a dimension in ur cars suspension which other pieces relied on in making the wheel have positive or negative camber. u can get adjustable camber plates in which u'll have control on how much - or + camber u have. so like i said:
    lower the care = more - camber
    which affects two things: handling and tire wear
    have fun rippin the turns lol
    91 CRX SOHC-550WHP 420TQ (Sold)
    02 WRX-224.4WHP 223.2TQ (Traded)
    01 S2000 (stock)-201WHP 130TQ (Traded)
    98 GSR (stock block) - 415WHP 340TQ...Hydro locked. Sigh
    91 240SX POS - 0 WHP 0 TQ (Junked)
    10 370Z (Sold)
    97 Civic DX (turd awaiting polish)
    98 GSR (built) - 606WHP 366TQ @ 20 psi on 93 octane
    what type of car is it?
    10 370Z (Sold)
    Certified Gearhead JstAneon's Avatar
    and how big is the drop?
    It depends on how many inches it is being lowered, I would say 1" is ok but 2"+ you'd better get a camber kit. I've noticed that some cars will only have either the front or back that needs a camber kit (lowered quite a bit for example my CRX needed a front but not a back, & on a buddies 99 Civic the rear camber was worst than the front.
    Just get the camber kit, & make sure you get an alignment afterwards to make sure everything is "straight".
    Rock the 40oz GTScoob's Avatar
    GA Tech
    You're going to need an alignment after the springs anyways so why not spend $40 on some camber bolts since you are going to have everything apart anyways.
    02 WRX Sport Wagon
    Where Am I
    mines lowered about 2 inches and the place that did my alignment has some sort of jig that takes the camber out, but they said its only for honda's, so they took all my camber out without me buying a camber kit...
    really? i've never heard of being able to adjust camber on a honda without some sort of upgrade. the alignment shop we refer our customers to has said over several occasions "pretty much everything can be adjusted except for camber." because of the way the suspension is made.
    10 370Z (Sold)
    Quote Originally Posted by loSiRcity
    Yea that sounds about right. Toe, caster etc can only be adjusted so much on stock parts.
    project cccheap!!!!!
    Winder
    speaking from experience here, i know that i had to but a camber kit for both front and rear for my DA once i lowered it...it's not a must but if you wanna save your tires then i'd go ahead and invest in it...a camber kit once is a hell of alot cheaper that tires every month or so....that's my
    1962 ford f-100
    "CHAMP"
    I asked a mechanic about it and he said cuz you have a newer car probably not. you probably dont need a camber kit in the rear.
    guys i got a 06 rsx type s. dropping the front about 1.4" and rear about 1.7"
    "CHAMP"
    anyone recommend a good set a camber kit made from japan?
    Quote Originally Posted by RUacurIT
    Its not necessary to get even JDM tyte camber kits, just use SPC or Skunk2. They don't cost much & are great.
