Results 1 to 24 of 24
Thread: My car idles from 1k-2k when warm and idle.
    Riverdale
    Default My car idles from 1k-2k when warm and idle.
    I changed the idle air control valve and it still does it..any of u guys know what it could be?
    Certified Gearhead civicracer5000's Avatar
    atlanta
    you should check the throttle position sensor (tps)
    WEST_SIDE
    what kinda car?
    and what would you check for on the TPS for a jumpy idle?
    -Ernie
    your moms house
    tps you can probe and check the TPS..my car is doing the same but there could be other possibilites too. are you throwing a cel?? have you bled your coolant system? that could be a issue as well
    FUCK B&D COMMUNICATIONS!
    WEST_SIDE
    Quote Originally Posted by b18hatch
    i know you can prob it but im asking why on a jumpy idle?
    atlanta
    Quote Originally Posted by SLow_POke
    the tps sends a signal to the ecu to adjust the fuel according to how open is the throttle if the the tps is malfunctioning idling occurs due to the fact that the ecu doesn't know if the throttle is opening or not
    Engine Builder hondasniper's Avatar
    SC
    If you aren't gettin any cel's then check your fast idle valve.
    Super Dave Z U L8R's Avatar
    Roswell
    or coolant temp sensor, or is your thermostat stuck open....does your heat work well?
    4G15 powered
    Covington
    Could be the idle control valve.My accord did that before i totaled it and thats what it was as well as the last thing i ever got to fix
    Macon
    check the fast idle thermal valve.its on the bottom of the thottle body. take the plate off the side and screw the round plastic piece all the way in, then 1/4 turn out.
    Land Rover LR3 HSE
    checking the fast idle valve is definetley good suggestion. where i work we get cars coming in all the time in limp mode (reving up and down between 1 and 2 k). just take one screw off the top and loosen the other and swing the cover out of the way. then get a flat head and put it in the slot and turn it clock wise (do not over tighten it) that platic peice inside just loosens up overtime
    Quote Originally Posted by loSiRcity
    exactly what i did.. my car idles beatuifully....
    what happens if you over tighten though?????
    i've just seen people do the hulk turn of a screw driver and brake so much stuff so i figure if i tell u dont over tighten it u'll be more careful about it. i havent broken one and i dont know of ne one who has i'd just hate for someone to brake something like and have to go spend money on what could have been a simple/free fix.
    91 CRX SOHC-550WHP 420TQ (Sold)
    02 WRX-224.4WHP 223.2TQ (Traded)
    01 S2000 (stock)-201WHP 130TQ (Traded)
    98 GSR (stock block) - 415WHP 340TQ...Hydro locked. Sigh
    91 240SX POS - 0 WHP 0 TQ (Junked)
    10 370Z (Sold)
    97 Civic DX (turd awaiting polish)
    98 GSR (built) - 606WHP 366TQ @ 20 psi on 93 octane
    Žanj-♠ ranj's Avatar
    http://forums.importatlanta.com/showthread.php?t=88966
    i made a write-up that could fix this, check it out.
    WEST_SIDE
    Quote Originally Posted by civicracer5000
    aww but wouldnt you get a MIL been the tpSENSOR? keither way TP is only .5 v at idle(CLOSeD). So if its a TPS and it was sensing open trotle even if a lil bit wouldnt theh revs stay high?
    and the FITV, would that fix only on cold start ups?
    -Ernie
    Woodstock
    Shit my tacoma idles at 2 k in the morning. No codes, just does that....
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    WEST_SIDE
    Quote Originally Posted by Blitanicle99
    of course when its cold.
    -Ernie
    you won't get a cel as long as the voltage is w/in the operating voltages. i've seen people come in w/ the tps connected to the wrong plug (thanks honda for using so many of the same plugs underhood) and no cel.
    just check the fitv... u don't even have to take the whole thing off.. just squirm your hands back there enough to take one screw off the back plate... loosen the other.. the plate will just hang there, and then u can tighten the plastic piece inside with your fingers... put plate back on...
    should take.. 10-15 minutes tops... unless u didn't tighten enough and have to do it again...
    stockbridge
    CAM ANGLE SENSOR, oh shit ive been working at FORD too long.
    WEST_SIDE
    Riverdale
    My light has been on because I have odb1 headers with only one bung and two O2 sensors...Ive drained the coolant system a refilled it..How do you bleed it?
    Quote Originally Posted by Z U L8R
    I changed the thermostat..The heat works too well..lol
    Quote Originally Posted by allmotoronly
    its a D16y8..I have a fit valve?
    Thanks for all the help and input guys!
    Quote Originally Posted by B18C-4
    yes you do, and like i said before, i made a writeup that you can follow to fix it if its the problem
    Riverdale
    Quote Originally Posted by ranj
    +1
