Thread: ABS removed
    Senior Member mccoy1178's Avatar
    Default ABS removed
    hey does anyone have info on how to remove the abs system and still have working brakes in a 94 & up integra? any info will be appreciated. thanx
    Mccoy
    the old man NAIZBST's Avatar
    look on honda-tech. Integra RS front brake lines and prop valve.
    Johns Creek
    Why do you want to remove your ABS? Is this a race car or a street car?
    Why?
    Johns Creek
    It makes no sense to remove it from a street car if it is working properly.
    On a racecar you would only remove it due to class rules. Otherwise, it is unlikely that you will be able to gain a significant amount of increased braking, and then only in the dry. In wet weather on the track, abs is almost always superior, and in dry, they are only close if the driver is an excellent racer. Otherwise, abs usually gives the advantage. I am also assuming that you have excellent tires. With less than optimal grip, you will generally benefit from abs.
    It took me years to get around to trusting abs because I came from a background of extremely late threshold braking (cars, not bikes). But even I like abs in wet weather conditions. I have my RX7 setup where I can control when I use it and when I don't want it. Right now, I need to replace the computer though.
    Acworth
    I agree leave it in unless it is givig you probelms. It can be a good help on tracks.
    HardParkin'
    duy, you have to remove all the lines, and use a NON ABS Brake Booster, And Master Cylinder. Also you will need the 4040 Prop Valve, and also the 2 brake lines from the Master Cly, to the Prop valve, and then the 2 from the prop valve to the driver/pass side brakes. Total of 4 brake lines.
    Where Am I
    just keep it, its to much work and money to remove you wouldn't even notice the difference anyway.....
