Thread: b20 block/ITR tranny
    Default b20 block/ITR tranny
    im buildin a b20 vtec in a few months and im buyin parts now.
    im guessing since an ITR tranny cam off a b-series motor it will bolt right up to the b20 block? would the ITR tranny be the best option or is there a better tranny out there?
    EF SQUAD FTMFW!!!!
    I've always heard that the jdm type r tranny is always the best for both quick gears and durability.
    ITR tranny will bolt up to b20 block.. its a good trans out of the box due to the LSD option and fairly short gearing..
    your moms house
    yes everything will bolt up fine and the gears are good about the only way you could get a better one is go with the 4.785 final drive or something like that but it should be fine like it is the shorter final drive equals more tire spin in a higher whp car which kinda sucks
    my clutch now is a cable clutch. i think ive heard of a cable to hydro conversion am i correct?
    EF SQUAD FTMFW!!!!
    your moms house
    Quote Originally Posted by SL65AMG
    yes hasport makes a kit and some other companys do as well you need it if you ever want to upgrade to a really strong clutch because the stock cable begins to strech and break
    Augusta, GA
    innovative, another company that makes the cable to hydro.
    There's a couple differant ITR tranny's...JDM '98+ has a 4.785 Final Drive while all USDM & '96-97 JDM have a 4.4 with a little longer 4th & 5th gear.
