Results 1 to 15 of 15
Thread: CAI tips ?
    Banned SE-Rious1's Avatar
    WINDER,GA
    Default CAI tips ?
    i just put a CAI on my 91 b13 sentra and sometimes when im sitting in first gear itll idle up and down then i give it some gas and it goes away im thinking something needs adjusted any tips ?
    WINDER,GA
    not a serious problem but i dont like any problems at all so need help ASAP
    itakepictures
    changaroopouch
    did u do anything to the iacv?
    WINDER,GA
    Quote Originally Posted by ekcivic9
    nah
    2.2 CL
    when my idle kept going up and down i replaced my distributor and it went away... not sayin thats the cas with your car but mite want to consider it
    WINDER,GA
    Quote Originally Posted by DA6
    i know thats not the problem cause it only does it now it has the intake on. i put the stock one back on and it stops but i need to find out what causes it with the CAI
    your moms house
    ARE YOU MISSING ANY HOSES?? LIRL AT DIZZY PROBLEM CAUSED BY PUTTING ON A CAI
    FUCK B&D COMMUNICATIONS!
    WINDER,GA
    Quote Originally Posted by b18hatch
    lol yeah i know . i didnt everything is hooked up the way it was before only 2 lines wur disconnected when putting it on but funny thing is it only does it every now and then.
    your moms house
    hmmmm....maybe its your vtec trying to kick in, lol
    you sure you put everything back the way it was?
    WINDER,GA
    yep all things are GO for launch and intact but then the idel issue when it does it sounds kinda like my buddys supra did when his MAF was going bad but mine isnt i know 4 fact and it only acts like that with the cai.
    Super Dave Z U L8R's Avatar
    Roswell
    does that car have an intake air temp sensor in the stock filter box?
    Gainesville
    could be the air sensor or another sensor...you could of bumped a vacum line while you were putting it on and possible knocked it loose...jsut check everything...and/or take it to a shop and let them look over it, most of the time they won't charge just to look over it, atleast i never have been...but that could be because i have made alot of friends...
    WINDER,GA
    Quote Originally Posted by §treet_§peed
    could be the air sensor or another sensor...you could of bumped a vacum line while you were putting it on and possible knocked it loose...just check everything...and/or take it to a shop and let them look over it, most of the time they won't charge just to look over it, atleast i never have been...but that could be because i have made alot of friends...
    ive checked everything 3 times now idk about a air temp. sensor maybe on the intake body but idk if a swhop w2ould tell me much cause it only does it everynow and then so might not do it with them at that time
    project cccheap!!!!!
    Winder
    take it to automotive repair source over by holly hill...teng will let you know whats up...
    1962 ford f-100
    WINDER,GA
    Quote Originally Posted by 92tegracer07
    the name is teng ? ill try i think it has something to do with the MAF i messed with it a lil and when i take the filter off it runs lil rough so i blew threw the body and it straightened out some so its either that or the heated wire or air compinsation sensor whatever but i notice when the MAF is disconnected it runs bad like it does sometimes when im sitting still so i know it has something to do with that but it never did anything before and i dont see how putting a intake on would change it it sucks air stock so im lost
