Thread: LSD in a B-Series Tansmission
    I did it all for the nook
    Charlotte, North Carolina
    Default LSD in a B-Series Tansmission
    Hey folks,
    I am still in my noob phase when it comes to hondas, but I I have a 1999 Civic coupe with a LS/VTEC mated with a 2000 Civic SI transmission. I wanted to know if I could add a limited slip differential to the transmission without any major modification to the transmission (cutting, welding, new gears etc). I am still learning to drive it (never drove a manual before) but I know that the LSD will offer better traction and less of a chance of the front wheel spinning out. Any help or advise would really be appriciated
    Quote Originally Posted by Game2954
    Hey folks,
    yeah the cheapest ting to run would be Integra Type R LSD. however youll need to change the ring and pinion gear and 1st to a 1.8l-ITR gear.
    i charge $450 to install it if the tranny is in the car.
    ($300 to drop trans and install, $150 to install differential)
    Parts wise your looking at $400-500 for the diff and gears
    or you can just buy a Quaiffe, ATS LSD for $900-1000 which are much better diffs
    HardParkin'
    look in the fs forum. snatch has a phantom grip LSD for sale
    Senior Member 99SI's Avatar
    Jackson
    I got lucky and got a hell of a deal on a jdm itr lsd. I haven't had any problems with it yet, but don't have a bunch of miles on it either.
    Because I eat RICE RiceBoy's Avatar
    I have a JDM type R LSD that will be a drop in for 300 bucks. Comes with bearings too.
    Jackson
    ^^not a bad deal at all, considering I paid 330 for mine including shipping from Japan. Then had to buy the ring gear and pinion from an itr to make it work right.
    Quote Originally Posted by PurpleGodzilla
    it will not DROP in without the rings and pinion gear. the differentials are different sizes, do you have the ring an pinion to go with it trihn?
    once again thanks for some knowledgable help! My only question now is does the CTR and ITR share the same LSD?
