Results 1 to 17 of 17
Thread: 95 Civic CX hatchback 1.8 turbo
    Certified Gearhead accrdpusha's Avatar
    Decatur, Georgia, United States
    Default 95 Civic CX hatchback 1.8 turbo
    My homeboy in Mississippi is selling his hatchback.
    ENGINE
    96 integra LS b18b1 swap with 117,000 miles on it (new timing belt, water pump, ignition coil, rotor, and plug wires) the swap was a OBD2 to OBD1 conversion but was done right with the integra axles, wire harness, shift linkages, integra motor mounts and integra wire engine harness (not cut up).
    Rebuilt Garrett T3 super 60 .60 A/R compressor .48 A/R exhaust (2000 miles on it)
    Aem intake filter
    Full race monster Stainless steel manifold w/ 50mm equal length runners
    Tial style 38mm wastegate w/ custom 1.5" dump tube
    Custom 2.5" downpipe w/ 2.5" flex pipe
    Custom 2.5" intercooler charge piping
    28x6x2.75" front mount intercooler w/ the end tanks painted black
    Blitz style blow off valve
    Stock Civic Si 2-1/4 exhaust piping with arospeed muffler
    Stainless steel oil feed line and custom oil return line
    Dsm 390 cc injectors w/ honda resisitor box and custom injectors seals
    Denso 190 lhp fuel pump
    Moroso clear distributor cap
    Full aluminum half size race radiator
    New XTD stage 3 clutch
    Engine Management
    Chipped p06 ecu w/ LS turbo map tuned for 7lbs (comes with 2 chips 1- turbo map, and 1 stock ls integra map just in case you have to get the car smogged and need to take the turbo kit off) I will also type up a detailed description of what features i programmed on the chip and leave it in the car for future reference or for the next tuner.
    Map includes:
    Lauch control @4000 rpms
    Rev limit @ 7000 rpms
    LED shift light programmed for 6900 rpms
    Boost limit set at 8 lbs (so you dont over boost)
    .75 degree retard in boost
    Speed limiter set @ 140 mph
    and the map it set up for 390cc injectors
    Interior
    Autometer ultra-lite separate boost and vaccum gauge (mounted in the a/c vent)
    Sunpro 2 5/8" Rpm tach (mounted on the top of the steering column)
    Blue Led shift light (mounted inside gauge cluster)
    B&M short shifter
    B&M tall leather (integra style) shift knob
    SUSPENSION
    Eibach sportline spring with tokico shocks
    Megan H-brace
    Upper front strut bar
    99 GSR blades
    Now a few of the bad things
    The car needs a new windshield, the interior needs a good detailing (seats are a little dirty), the front driver side under dash panel is broken, car needs minor body work, a paint job, the a/c was removed when the car was turbocharged so it has no a/c, need a new oil pan gasket and Cam plug. If car is bought for price requested, all of these will be fixed plus a full tank of gas and fresh oil change.
    The motor has 117,000 miles on it. Get contact for questions or vin number.
    PRICE: ONLY $5500 OBO
    Contact info:
    Seller: Pete- [email protected]
    Me: Football- 678-617-8599, or [email protected]
    CALL AFTER 10:30 AM AND BEFORE 11:00PM
    Owner is willing to meet halfway.
    About to approach beast mode
    Banned SE-Rious1's Avatar
    WINDER,GA
    clean hb GL
    night time bump
    full race? or full race style?
    that is NOT a full race manifold, its an SS AC
    Seems like a good bit of stuff to fix, o well bump.
    your moms house
    Quote Originally Posted by Mr. 2JZKIDD
    damn...how can you tell?
    FUCK B&D COMMUNICATIONS!
    cause i just installed one on a civic. same style.
    and if you know what a true FULL RACE manifold looks like, its not that. they use different material than that.
    Thats a copy of an old 1fab or lovefab manifold, but its taiwanese, aka XS power/SSAC
    your moms house
    AH...Your knowledge is overwhelming!
    notice how it says BLITZ "STYLE" bov and TIAL "STYLE" WG. thats an EBAY kit, i recognize the blue couplers an cheap stainless return line too.
    still not a bad kit, but its not as good as a full race/drag/turbonetics kit.
    your moms house
    LIRL, damn....nice catch...i didnt even notice that
    G-net
    Quote Originally Posted by wHtKoNgDrIfT
    clean hb GL
    clean????? holy shit i would hate to see your example of dirty.
    good project though
    One Big Ass Mistake America
    your moms house
    Quote Originally Posted by SLOWR/T
    good project though
    he lives in winder...lol....
    when i had my primered del sol with a crooked bumper and miscelaneous(sp?) things wrong, this guy pulled up to me at 81 and main street and was like "thats a clean honda!" i was like uh, thanks....
    ^^ AHHAHA ! - GL with the sale.
