Thread: Crx B16A swap
    Default Crx B16A swap
    I have a '91 Crx and i have a B16A Obd2 what do i have to do to make it run on my crx. i was told that i needed to put and obd0 distributor and alternator. Also i have a semi built head the only thing missing are cams and cam gears and i want to put ctr pistons will the compression be more then 12.5
    Gainesville
    ODB0 DIZZY AND ECU. SINGLE WIRE O2 SENSOR. 91 CIVIC AND CRX SI ENGINES HARNESS. ULL NEED OLDER INJECTORS BC THE PLUGS ARE DIFFERENT AS WELL I THINK. HOPEFULLY U HAVE A CABLE TRANNY OR ULL HAVE TO GET A CABLE TO HYDRO CONVERSION KIT FROM HASPORT. I THINK THATS IT. IF I THINK OF SOMETHING ELSE ILL POST. IF SOMEBODY SEES SOMETHING I POSTED WRONG LET ME KNOW.
    Like Btec said:
    OBD0 Distributor or a Conversion harness
    OBD0 ECU (PWO or PR3)
    OBD0 Injectors
    OBD0 ENGINE HARNESS- If your car is a DX, then you need to convert to MPFI
    If you have a hydro tranny youll need the hasport cable to hydro mount kit, or a cable B series tranny
    i plugged an obd2 injector to my wiring harness and it fit perfectly. my crx is Si. the obd0 ecu that i have is a pm5
    doesnt matter if it plugs in, they use a resistor box on OBD0, obd2 DOES NOT
    Quote Originally Posted by JDM crx
    WELL OBD0 INJECTORS ARE PEAK AND HOLD AND OBD2 INJECTORS ARE SATURATED SO THEY STILL WNT WRK.
    o aight thanx. does a pm5 ecu work with my swap
