Thread: Code 23
    Default Code 23
    Knock sensor,
    car starts and runs no codes, after 5 minutes of driving code 23 comes on.
    shut the car off no code, unplug the knock sensor no code, drive the car for a few code comes on. is the knock sensor bad?
    any input would help
    Oct 2003
    is ur motor Kocking? timing advance too much?
    LAWRENCEVILLE
    Is the knock sensor wired up? was the engine swaped in?
    Hella stock member!
    Engine is not knocking, timing is tdc
    i swapped the motor but there was no knock plug so i wired it to pin d3 obd1
    car makes no sense...
    Gainesville
    try www.honda-tech.com that is if nobody here can help you...
    Super Dave Z U L8R's Avatar
    Roswell
    it always helps when you specify at the beginning what kind of car with what kind of motor.
    I GOT THAT CODE BC MY WIRING WAS SHIT. I BUTT CONNECTED THE PLUG TO A PIECE OF BULK WIRE AND I CAME APART AT THE PLUG ONCE AND AT THE ECU ONCE. IM SURE SOMEBODY ADDED THAT WIRE TO UR CAR SO CHECK UR SPLICES.
    IM ASSUMING UR CAR IS A SWAPPED CAR.
    I changed the ecu and the problem is corrected that's for the replies...
