Thread: b16 crank case vent on valve cover lotta pressure
    noob?call it transfer
    Bama
    Default b16 crank case vent on valve cover lotta pressure
    the crankcase vent on my b16 turbo has alot of pressure and is blowing out grey smoke. shouldnt it be sukin instead of blowin. i think the motor is toast give your on it
    Some people are like slinkies!good for nuthin but u cant help but smile if you see one tumble down the stairs
    Factory Intgegra Type R LSD $300 PM Me.
    Bama
    damnit all the veiws and no answers wth?
    __DailyGrind
    do you mean the endyne crank case ventilation kit? if so, a little gray smoke is ok, as it its venting the pressure in the crankcase. at idle, a little is ok. now, if it blows out like no tomorrow, something is wrong. do a leak down test. you will not know for sure if its toast until then.
    Bama
    coo thanx man its blowin like a freght train . i will check compression i think its a blown head gasket ora broke ring i hope it didnt warp the head thanx bro
    Bama
    HAVENT HAD TIME 2 COMPRESSION CHECK YET ANY ADVICE ON IT B4 I DO IT? ANYBODY
    Duluth, G-nett
    dont do a compression check. do a leak down test instead.
    __DailyGrind
    ^^^ditto
    Bama
    10-fow
