Results 1 to 17 of 17
Thread: jumpy Idle
    h series
    norcross
    Default jumpy Idle
    i have a bad idle. it starts to jump from 900-2000 every time im at a red light and its not only annoying but a waste of gas. my CEl is also one but its and off and on thing. ive talk to alot of ppl about the problem and even took it to Oz to fix it but it still isnt straight. Alot of ppl told me it could be ether my iacv or my vacuum line i was wondering if anyone would be able to help me or vouch for someone thanks
    WEST_SIDE
    seen that its all the time not jsut at cold starts up ot eliminates the fitv.
    is you checked all you vac lines i would run a scan since u mention getting a MIL
    btw. what kind of engine, years, car?
    -Ernie
    IA Juinor Member Mr_S13®'s Avatar
    Cumming, Ga
    Up under your throttle body is a little gold plate with 2 screws...take the plate off and there will be a little hub with 2 slots on each side. take a small screwdriver and spin the hub until it touches base with the spring. this should fix your problem!
    If not, then it could be vacuum related so check all your vacuum lines and listen really close around your intake manifold, and throttle body. If either one of those gaskets are bad then that would also cause it.
    [SIGPIC]
    vac lines, maybe tps!?
    h series
    norcross
    i have an h22 in a 94 accord
    h series
    norcross
    would it be better for me to clean the iacv or just buy a new one? i dont want this problem to occure so i want the best solution
    too many projects
    Greensboro, NC
    buy a new ivac, cleaning it doesnt always take care of the problem and can cause dirt to back up in the them. we have bought them new from honda and had to exchange it becasue it was bad from the start. G/L but thats your idle bug.
    11 camry se
    99 cbr 900rr on n2o
    97 accord h22 on 25psi
    06 scion xb
    01 expedition
    h series
    norcross
    how much would it be new from honda?
    h series
    norcross
    ok i changed the iacv today and still got the same problem any further advice?
    Macon
    Quote Originally Posted by an0therh22
    accords and preludes are imfamous for having FITV and IACV problems. First, on the side of the throttle body there is a brass colored plate. remove the plate. There is valve inside. turn the white plastic piece clockwise until it stops. If that does not fix it, then remove your IACV (front center of IM) and clean the screens out. check to see if it is sticking if possible. If it STILL has a problem (other than vaccum lines which you should have checked first) then it may be one of the gaskets, either the IM gasket, or one of the two secondary runner block off plate gaskets. Also check the O-Rings on the injectors. I also had a problem with a few of my H22A's breaking IM studs, which will eventually cause a vaccum leak. The EGR valve gasket can also blow out (although rare).
    Land Rover LR3 HSE
    h series
    norcross
    my motor is throwing ERG so i have no idea what causing the problem. i just got the iacv changed today and i had Oz look at all the lines so im thinkin it wouldnt be that ether.
    flowery branch
    Quote Originally Posted by allmotoronly
    accords are imfamous for having FITV and IACV problems. First, on the side of the throttle body there is a brass colored plate. remove the plate. There is valve inside. turn the white plastic piece clockwise until it stops. If that does not fix it, then remove your IACV (front center of IM) and clean the screens out. check to see if it is sticking if possible. If it STILL has a problem (other than vaccum lines which you should have checked first) then it may be one of the gaskets, either the IM gasket, or one of the two secondary runner block off plate gaskets. Also check the O-Rings on the injectors. I also had a problem with a few of my H22A's breaking IM studs, which will eventually cause a vaccum leak. The EGR valve gasket can also blow out (although rare).
    try that i have an h22 lude and after i put my pulley kit on i had the same problem i just adjusted my idle control valve and it stopped
    h series
    norcross
    yea we think its the IM gasket but not shure i was just wondering what everyone else thought about this dam hondas and there bad idle i think mine is the worst ive seen cuz ive tried adjusting the idler control valve but it still didnt work i even retarded my dizzie than adjusted it but still the same problem
    flowery branch
    damn that sucks yeah mine was bad my check engine light came on and startin stallin for no damn reason and shit!!! damn hondas!!!!! so many problems!! but when there good there good!!! good luck with it man
    Macon
    don't adjust the distributor... that has nothing to do with a jumpy idle. It is a vaccum leak of some sort. When the FITV or IACV sticks, it lets too much air in and the engine revs higher. One time my IACV fell off and my car idled at 4200rpm... all from a hole that is about 5/8" around... I ducktaped something over it ( i think it was a quarter, i cant remember) so I could make it home.
    Hey when you are driving down the road and you let off the gas, does it decellerate hard? Sometimes the butterflies in the IM will stick. If the bushings in them wear out they will get stuck. It happened to me once. The bushings are nylon, and somehow they deteriorated and the butterfly got stuck open, which makes it run like shit at low RPM...
    Land Rover LR3 HSE
    h series
    norcross
    yep thats exactly what happens i dont understand this whole butterfly thing so can u clearify it?
    Super Dave Z U L8R's Avatar
    Roswell
    check coolant temperature sensor ( 2 wire for the computer not the 1 wire SENDING UNIT that's for the guage )
